Results 1 to 10 of 10
  1. #1
    Platinum Member bucktaker's Avatar
    Join Date
    Apr 2010
    Posts
    606
    Sw Ohio
    Kubota L5740 FEL
    Default 4000 series CUT vs 5000 Utility
    I am researching a replacement tractor to last me the remainder of my life currently 46
    I am comparing a 5045e to 4320 cut I am sure either tractor would do my typical tractor chores. rough cut mowing, grading, loader wk around my 10 ac funny farm. But I wonder if the CUT with electronics sensors and controls would cost more in repairs over the life of the unit.
    And if the need arose would the 5045e really be able to do more HD work?
    Both would be similar with loaders, power reverser for the cut and 9/3 gear,
    rear remotes, adjustable links, r1 tires
    Any one with repair history on the 4000 series and or the 5000 series?
  2. #2
    Super Member
    Join Date
    Feb 2008
    Posts
    7,738
    somewhere usa
    stuff
    Default Re: 4000 series CUT vs 5000 Utility
    I had to think about your questions for some time before posting.
    In the past tractors were simpler for sure with less features available than the newer tractors, changes in models were less frequent too. For most of the large manufacturers the tractors were built in the US and parts were available for a longer length of time. I have an 820 utility tractor and most of the parts are still available for it but not all of them. I should add that this tractor even though it is about 35 years old is a German built 3 cylinder model. This has been a good basic tractor and is still in good condition today.
    Moving to the present day I have currently a 110tlb 2005 model with about 700 hrs on it and a 4520 2009 model with about 200 hrs. Both with ehydro transmissions. These machines are both more complex than the older 820 but are much more user friendly too. Problems with all three of these tractors has been minimal.
    I have had lots of tractors large and small over the last 35 or 40 years and can say that most all of them have been good. I like yourself am more concerned about what the future will hold. I have reservations about expecting the newer tractors to have long term parts availability as compared to the past, and that goes for all manufacturers. That said I am not going to assume that the tractor I buy today will be around with parts still available for it 35 years from now. It would be good to know how long you are planning on living?.
    I can tell you this much though, having the newer models with ehydro, top and tilt, IMatch hitch, high power to weight ratio and a nice cab make a big difference in how pleasant they are to operate. In my view being able to manuever a tractor in close quarters with ease is very important and would rule out the 5045e which does not offer a reverser tranny.
    My choice for a 10 acre place would be similar to what I have now and would caution you not to believe that buying a simpler tractor will insure it will last longer or have fewer problems. The real problem facing the long term lifespan of future tractors will be parts availability not their durability IMHO.
  3. #3
    Gold Member Wombat125's Avatar
    Join Date
    May 2008
    Posts
    406
    SE Wyoming
    John Deere 5303
    I was in a similar situation a couple years ago. I opted for the 5000 tractor for a few reasons
    1. The 5000 was simpler and heavier. I have zero evidence that the 5000 is more reliable, but simple is intuitively pleasing to me.
    2. I don't have any obstacles or maneuverablity concerns on my property.
    3. I grew up on hydro, but I don't mind gears.
    4. When it comes to moving snow, there is no such thing as too big.
    5. I can run any of the "estate" sized implements without every giving tractor capacity a second thought.
    6. The 5000 series tractors were cheaper.
    Here are some numbers from January of this year.
    From the deere Configurator:
    $32,629 -- 4720 Open Station
    $40,499 -- 4720 Cab
    $24,474 -- 5065E MFWD
    2008 JD 5303 with 522 Loader, iMatch, 6' Frontier Rotary Cutter, 7.5' KK Disc, 7' Road Boss Grader, 8' KK Blade
    1966 JD 110H with Snow Blade, Mower Deck
    1968 Case 195 with Snow Blade, Mower Deck, Trailer
  4. #4
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Quote Originally Posted by bucktaker View Post
    I am researching a replacement tractor to last me the remainder of my life currently 46...............
    How long do you expect that to be?
  5. #5
    Join Date
    Apr 2010
    Posts
    606
    Sw Ohio
    Kubota L5740 FEL
    Quote Originally Posted by beenthere View Post
    Well that is the million dollar question
    Guys Thanks for your replies and I think you hit the nail on the head. Parts will be discontinued faster and go obsolete way before they had in the past.
    Which is one reason I am sticking to JD or possibley Kubota.
    Both 4000 cuts and ut 5000 been around for a few years what has been typical mean time between repairs are we going 500-2500 hrs ?
    Who has the most hours on their 4000 or 5000 series?
  6. #6
    Join Date
    May 2009
    Posts
    628
    South Mississippi
    2008 John Deere 5303 MFWD
    I have a 5105 which is similar to the 5045. I have been very pleased with mine and have used both 6' and 8' 3PT disk and pull a 6' cutter. I like the size of this tractor and if changing anything, I would add the 4WD option. I imagine either one would do the job for you, but I too tend to lean toward simplicity.
  7. #7
    Join Date
    Jan 2010
    Posts
    66
    JD5045e
    I have had the 5045e now for a year and am very happy with its performance on 20 hilly acres. FEL, MX6 bushhog, 7ft boxblade. I am still learning about this tractor, but overall I really like it. Has easily done everything I have asked of it with now over 200 hours. Can't speak about future parts yet, but I have confidence a dealer will help me when needed. The "four wheel drive" has proven its worth numerous times. This is a fun toy.
  8. #8
    Elite Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    4,862
    Kasilof, Alaska
    JD 5075M; JD 110 TLB; Ford Ferguson 9N: JD X300R
    If the odds are short... Don't hold back now!!! Get EVERYTHING!!
    My experience is if you use your tractor with a measure of sense and keep everything up to snuff on hourly maintainance - you shouldn't have to worry about anything for several thousand hours - not a few hundred hours.
    With either a 4000 or 5000 series machine.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  9. #9
    New Member
    Join Date
    Mar 2010
    Posts
    12
    Wisconsin
    JD 4720
    I have 430 hours on my 2005 4720 and it has been trouble free so far.
  10. #10
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,799
    Red Oak, Texas
    JD 5525 and 4520
    I own both a 4520 cab and a 5525 cab.
    Unless you are doing some serious loader work or wanting to use some high PTO implements the 4320 would be fine.
    I had a 4720 open station and it was a good tractor - pretty much no problems.
    4520 cab have had for 2 years in August. I have had a couple issue: ECM and AC went out.
    5525 has been very good. Only not my fault problem was a AC switch.
    There pros and cons with both machines.
    D.
Similar Threads
  1. 5000 series
    By Farmwithjunk in forum John Deere Owning/Operating
    Last Post: 04-05-2011, 12:13 AM
  2. Is the JD 4000 series much more stable than the 3000 series?
    By ArtVandelay in forum John Deere Owning/Operating
    Last Post: 06-30-2007, 12:07 AM
  3. 5000 series 60" deck blades
    By OhioGuy in forum Cub Cadet Yanmar & CUTs
    Last Post: 12-06-2005, 08:37 AM
  4. JD 4000 series cab
    By Hillbilly in forum John Deere Owning/Operating
    Last Post: 12-21-2001, 04:23 PM
  5. Financing FYI... 6.9% Financing on 4000 & 90 Series
    By Muhammad in forum John Deere Buying/Pricing
    Last Post: 02-02-2001, 12:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
