Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
  1. #1
    New Member
    Join Date
    Mar 2006
    Posts
    16
    East Central Kansas
    John Deere 5105M
    Default JD 5105M vs. JD 6330
    I´ve been a member of this forum for a while now reading and researching John deere tractors in the 75-100 hp range. A little background first. My father and I have 45 head of cattle and bale around 350 round bales of hay per year in east central Kansas. We have our JD 535 baler paired with a 1992-75hp JD 2755. Currently we cut the hay with a JD 260 disk mower paired with a 1975-84hp Ford 7000. This tractor has been rock solid through the years but we've decided to update this fall.
    We have narrowed our decision to either a new 5105M or a slightly used (<500 hours) 6330. The 5105M is 90hp at the PTO and the 6330 is 85hp. Both tractors are priced in the upper $50´s.
    I visited the four-state farm show a couple weeks ago in Pittsburg, KS and was able to see a 5095M next to a 6330. Both tractors would be fitted with SL-loaders, MFWD, and cabs. Both have the power reverser and several options for transmissions. We have no intentions of working ground; these will be used strictly for baling hay and feeding hay during the winter.
    In talking to the Deere dealers, they're trying to persuade me into a 6-series in the possibility that we expand our operation in the future. I'm leaning towards the 5-series because it will satisfy the needs I have. We not looking to expand, as we both have full-time jobs besides our small ranching operation. I've heard it said that the 5M Series is basically a 6-series tractor in a 5-series body. I like the idea of a smaller size with the same amount of power.
    I'm looking for suggestions. Which of the two tractors listed above would you choose and why? Thanks for your time.
    Attached Thumbnails Attached Thumbnails JD 5105M vs. JD 6330-5105m.jpg   JD 5105M vs. JD 6330-6330.jpg
  2. #2
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,336
    NW Oregon
    Deere 317 & L118
    Default Re: JD 5105M vs. JD 6330
    what is the price difference between the two? if the 6330 cost less you will get more for your money. just my Opinion.
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, CU72 Jake Rake, Middle Buster, 60" Landscape rake, 54"x 48" Pallet forks
    2005 John Deere L118
    42" deck
    Check out my rakes: www.Jakesimplements.com
    Check out the latest small engine I am working on: http://www.northwestsmallenginerepair.weebly.com
    Member of the TBN "Young gun" Club
  3. #3
    New Member
    Join Date
    Mar 2006
    Posts
    16
    East Central Kansas
    John Deere 5105M
    Reviewing prices on machinefinder and tractorhouse, a new 5105M is around $58K. A like-new 6330 can be had for right around $62k. More for your money, what will the 6-series do that the 5-series won't do on a small ranching operation? I understand the difference if I was engaging ground work. Thanks.
  4. #4
    art
    art is offline
    Super Member
    Join Date
    Apr 2000
    Posts
    5,849
    central New York
    all makes and models
    One thing that you have to put up with the whole time of ownership is engine noise! Quieter engines are normally from a better smoother working design.
    My recommendation would be to listen to both at the same time, if not possible at least at two different times and you should hear the difference. I'd be taking the 6000 series because of that reason on it's own!
  5. #5
    Platinum Member Edward. S's Avatar
    Join Date
    Nov 2009
    Posts
    641
    Somewhere
    John Deere
    I think you should get the 6330 these tractors have hella good resale value no joke.
  6. #6
    Veteran Member JESSE1's Avatar
    Join Date
    Nov 2003
    Posts
    1,057
    Kilgore, Texas
    JD 6400
    I have a '96 85 hp 6400 that's been a great tractor. I've never driven a 5100 series tractor but looking at them side by side the 6000 series looks much more substantial. I also pull a JD 535 baler and I think the 6000 series will handle the weight of the baler better.
    6400 John Deere w/ cab, JD 535 Baler, 997 ZTR Diesel, 72" 7 Iron deck, John Deere 855D 4x4 Diesel Gator
  7. #7
    Super Member
    Join Date
    Feb 2008
    Posts
    7,736
    somewhere usa
    stuff
    The 6330 has more hydraulic flow capacity, class II/III hitch, longer wheelbase by about 8-9 inches, more weight about 1,500lbs. A slightly larger tractor overall which when handling bales in the winter of the same size will have a slight edge over the 5105M.
    I would prefer the 6330 over the 5105M, while both will handle the bales and haying operation why limit your ground engaging capabilities? Better to be prepared since who knows what the future may bring.
  8. #8
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,799
    Red Oak, Texas
    JD 5525 and 4520
    Default
    Quote Originally Posted by erervin
    Either tractor will suit your needs. All things being equal I would go 6330
    D.
    Darin Divinia
    DDR Longhorns
    Registered Texas Longhorns
    http://www.ddrlonghorns.com/
    Follow us on Facebook:
    http://www.facebook.com/DDRLonghorns?ref=ts
  9. #9
    Platinum Member rutwad's Avatar
    Join Date
    Jul 2006
    Posts
    602
    Alabama
    John Deere 6605
    Another vote for the 6330.....
  10. #10
    Elite Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    3,088
    Giddings, Texas
    JD 4310,JD5420
    The longer heavier tractor will ride better on a rough field.
    The lighter tractor will tread lighter and won't leave as bad of ruts in wet conditions.
    If the price were the same, I'd vote 6330.
    You can put a gold saddle on a donkey but it's still a donkey.
Similar Threads
  1. My Sub Compact "TLB" Review (BX24, JD 2305, and MF GC2310)
    By Airic in forum Buying/Pricing/Comparisons
    Last Post: 03-06-2008, 11:03 AM
  2. Kubota Grand L 3240 hst vs JD 3320
    By farmerjim62 in forum John Deere Buying/Pricing
    Last Post: 12-01-2007, 09:55 PM
  3. JD 3720 or Toolcat
    By DocD in forum John Deere Buying/Pricing
    Last Post: 09-09-2007, 05:02 PM
  4. JD 110 TLB Purchase
    By tractorlogger in forum John Deere Buying/Pricing
    Last Post: 02-23-2007, 10:21 PM
  5. Dealer Bizzare JD Dealership Exp.
    By TomKioti in forum John Deere Buying/Pricing
    Last Post: 11-22-2006, 07:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
