Results 1 to 5 of 5
  1. #1
    Gold Member BethesdaEC's Avatar
    Join Date
    Oct 2010
    Posts
    448
    Ellicott City, MD
    JD 2520
    Default 2520, Switching Between Loader and Front Blade
    How quickly can I switch between the 200CX loader and the the quick hitch 54 inch blade on a 2520? Does the front quick hitch bracket have to be removed for the loader bucket to clear the front of the tractor? Also should I remove the backhoe with the blade attached since it could make the front very light or should I keep it on for the ballast?
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,964
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: 2520, Switching Between Loader and Front Blade
    10 to 15 min tops to change over, faster after you do it a lot. Yes, the QH will need to be removed, but that is just one pin.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Join Date
    Aug 2010
    Posts
    183
    Southern Ontario Canada
    JD X495 & JD2520
    I also have a 2520 with the QH and 54" blade. You didn't mention it, but if you have a MMM, you will need to change over the front bracket that holds the front arm of the MMM, to the bracket that holds the front QH.
    No big deal, but it seems a lot of folks don't realize there is one bracket for the MMM and a different one for the QH, so I just thought I would point that out in case you didn't already know.
    REV
  4. #4
    Join Date
    Oct 2010
    Posts
    448
    Ellicott City, MD
    JD 2520
    Quote Originally Posted by revitupfaster View Post
    REV
    I have a Bob-Cat Fast-Cat Pro for mowing duty, so no MMM for me. Can you leave the quick hitch bracket on the front while the loader is on, or do have to remove it?
  5. #5
    Join Date
    Aug 2010
    Posts
    183
    JD X495 & JD2520
    Quote Originally Posted by BethesdaEC View Post
    Since I have both the MMM and the front QH, I have 2 different removable brackets that fasten onto the front of the tractor frame. One holds the mower front arm, and the other is required when you mount the QH, which ultimately holds the blade, and has the hydraulic cylinders for up and down and angling the blade.
    I'm sure there won't be enough room to leave the full QH assembly on with the FEL, but the bracket to which the QH is mounted should be OK. It's the QH itself that sticks out in front of the frame and would interfere with the loader.
    I just got my 2520 in September, so have not switched it over for blade duty yet, but it looks like there should be enough room for the QH mounting bracket itself.
    The pic shows the QH, with the bracket it mounts to in the upper right side of the photo.
    REV
    REV
    Attached Thumbnails Attached Thumbnails 2520, Switching Between Loader and Front Blade-002-2-jpg
Similar Threads
  1. tires
    By Waterrat in forum Parts/Repairs
    Last Post: 03-13-2009, 06:23 PM
  2. Info Needed: Boom-Mounted Blade for a 430 Loader
    By rssteube in forum John Deere Buying/Pricing
    Last Post: 04-30-2004, 02:37 PM
  3. John deere 52 loader
    By Dennisfly in forum John Deere Owning/Operating
    Last Post: 11-09-2003, 09:28 PM
  4. Front End Loader & Box Blade on L3130
    By icat in forum Kubota Buying/Pricing
    Last Post: 05-09-2003, 02:43 PM
  5. lifting a pallat with front loader
    By waters in forum Kubota Owning/Operating
    Last Post: 05-24-2000, 11:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
