Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    New Member
    Join Date
    Aug 2011
    Posts
    17
    None
    Default 5055e vs 5075e
    Does anyone see a reason to not get a 5075e over the 5055e, I am new to tractors and decided the tractor I like is a 5055E the dealer has a 5075E in stock and can anyone point out any reason to not get the extra horse power? The price difference is not that big of a difference, i think they want to move the one they have, have researced the prices and both are good deals, anything i need to know about the 5075e vs the 5055e? Thanks
  2. #2
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    Default Re: 5055e vs 5075e
    No sir,I think they are close in size and if you got the need and $$$ for the 5075,I would get it. Im going off of nothing so I really dont know what you will be doing with the tractor but I will say you dont need a 5075 to operate 6ft equipment........
  3. #3
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Identical machines - frame and engine, running gear. Difference is turbocharger, injector pump and injectors.
    Added Hp gives you a margin to grow with on attachments and implements. Bigger mower, run a baler, etc., etc.
    If the cost is close - the decision ain't...
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  4. #4
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,423
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Quote Originally Posted by AKfish View Post
    AKfish
    After having the new tractor for awhile what is the verdict?
    I take it you are satisfied with your decision to move from a 65 hp to the 75hp model 5075M?
  5. #5
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    2,175
    W. Central Louisiana
    JD 5083E; JD 5085M; NH TN70A; Ford 2600
    Quote Originally Posted by Khiggins View Post
    Does anyone see a reason to not get a 5075e over the 5055e, . . .
    The ONLY thing that I can think of is that the higher HP engine will probably burn a little more fuel. Depending on how much and how hard you work the tractor, you may not even be able to tell.
    As already mentioned, the advantages to more horses under the hood are numerous. When I was looking last year, I would have gladly taken a 5095M instead of the 5085M if the price had been close.
    '12 JD 5083E Cab MFWD FEL
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    Vermeer 504R round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Krone 5.52 Tedder; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '95 Kenworth.
    "I've come to the point in my life where I can't remember if I've lost my horse or just found a rope."
  6. #6
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    One other small thing to consider is cooling capacity and air filter capacity. As mentioned before the 5045e through the 5075e are identical except for the air/fuel delivery amounts to the engine. The cooling capacity on the 5045e is more than adequate, but I can't speak for the larger hp tractors. Also the larger hp is going to be using more air (larger turbo) so the air filter will plug up more quickly. If you don't work a lot in real hot or dusty conditions it may not make any difference. Then again Deere may have enough reserve capacity in both those systems for the large hp models.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  7. #7
    Silver Member JD3520Turbo's Avatar
    Join Date
    Oct 2008
    Posts
    181
    Holt, MO
    2013 5083E Limited
    When I bought mine, if the price had been close, and the dealer had a 5101E, I would not have hesitated in buying the bigger one.
    The only difference is how much fuel is going into the same engine. Thats really what makes HP in diesels. Putting more fuel in it and putting it in a little earlier in the crank rotation. Maybe run a little higher turbo boost, but these engines can take it.
  8. #8
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    Quote Originally Posted by jenkinsph View Post
    Truth be told, Steve - if I would have settled for the 65Hp - I'd have regretted it! I've got enough tractor to consider a higher capacity square baler and a small round baler, now.
    The 50Hp @ pto would have left me on the lower edge of that equipment upgrade and really stuck.
    That said... I almost wish I'd gone to a 5095M. That's about the bottom of the Hp line for a Silage Special round baler. IMO - the difference between the 5075M and the 5095M is about on a par with comparing a 3020 vs 4020. Granted, the 4020 is likely 1,000lbs heavier and the 95M is only about 500lbs heavier but the Hp difference is on track.
    But... if wishes were horses - everybody would ride!! Had to draw the line at some point and I need a mower/conditioner more than a Silage round baler.
    AKfish
  9. #9
    Veteran Member GreatWhitehunter's Avatar
    Join Date
    Sep 2006
    Posts
    1,909
    Eastern CT
    JD 110 TLB
    AKfish
    AK, why stop there? Why not just step into a 6000 series? Unless your a full time farmer how much more do you really need? Do you have a herd of cows/horses? Are you selling the hay? My other pet peave is you don't post enough pics of the A the tractors and B the unsurpased beauty of AK.
    Matt
    Deere 110 TLB, 16' Load Trail Low Pro Dump Trailer, 2015 GMC 3500HD Duramax, Kawasaki 4010 Mule,21' Cam Superline Split Deck Tilt Trailer
  10. #10
    Platinum Member dntfxr's Avatar
    Join Date
    Aug 2007
    Posts
    514
    north Louisiana
    Ford, LS
    Default
    If the money is close I'd go for the extra hp. As others said fuel consumption is probably the main difference. Let us know what you decide! I'll probably end up with a 5e myself, just got to get sone loose ends tied up first. Don't forget pics!
    "Even a tuff ol thistle makes a good boot cleaner.."
    LS XR4155C
    Ford 3610
    Ferris is700 61" Vanguard BB
Similar Threads
  1. JD 5065e vs JD 5075e
    By JD BUCK in forum John Deere Owning/Operating
    Last Post: 07-28-2011, 01:08 AM
  2. John Deere 3032e vs New Holland t1510 for 60acres
    By Radiater in forum Buying/Pricing/Comparisons
    Last Post: 05-06-2011, 04:25 PM
  3. Comparison JD 5075E vs Kubota M7040SUD
    By mdelmarcelle in forum Buying/Pricing/Comparisons
    Last Post: 03-28-2011, 07:30 AM
  4. JD 5055E vs Kubota MX 5100
    By jfh0jfh in forum John Deere Buying/Pricing
    Last Post: 11-05-2010, 10:03 PM
  5. 5 years ago today
    By Tdog in forum Related Topics
    Last Post: 08-31-2010, 11:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
