revitupfaster
[QUOTE
As you stated, not really needing snow removal equipment very much,IMO,you may end up disappointed using either one of these attachments. They really aren't designed for snow duty,especially the box blade. The loader......eh,I used it my first year because that is all I had,but now I have a snow plow,and oh man, night and day difference. [/QUOTE]
Here here......one of the reasons I went for the 2520 was to hopefully be able to plow snow, without having to use chains. I have the R4 tires on mine, which have stiffer sidewalls, and a more aggressive tread, that make them better for FEL work, although a lot of folks didn't seem all that impressed with the winter tration ability of the R4.
I originally had the JD 54" and quickhitch blade setup on my X495, and of course had to use chains. When I bought the 2520, I upgraded the quickhitch to fit the 2520, and on the advice of this forum, purchased the ballast box for added winter traction. WOW.....with that loaded ballast box attached, I mostly plow my 300' driveway without even using 4wd. My drive is pretty much flat, but the 2520, JD quicktatch blade and BB can certainly handle any snow we get, and here in southern Ontario Canada, we usually get our share.
I guess what I'm saying is that I agree with Greg, the blade is far better than the loader for snow removal. Being able to angle the thing to either side sure lets you push the stuff anywhere you want without having to make multiple runs at different approach angles. So if you are thinking of bundling a few attachments in the deal, the front blade would be something I would think about.
I can't comment on the 2520/3005 question, not really sure of what the differences are. There doesn't seem to be a lot of discussion on that model as to how it stacks up to the 2320/2520/2720 series.
Good luck with your deliberations.
Rev
Rev
