Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    TBJ
    TBJ is offline
    New Member
    Join Date
    Feb 2012
    Posts
    3
    Lake Mary, FL
    Default Best JD Subcompact for needs
    Hello,
    New member, but have enjoyed numerous threads on all range of topics. Very informative. Hoping to gain some advice on JD Subcompacts.
    I'm purchasing 20+ acres in Upstate So. Carolina as a second home/hobby farm. The 10-14 acres I will be maintaining are mostly "smooth" terrain but with some "rolling" elevation changes. Will be mowing approx. 5-8 acres of existing pasture for "aesthetic" purposes (less than finish cut is ok). Will also maintain another 5+ acres of more weedy terrain with a fair amount of trees. Initially this portion will require some heavier duty brush cutting, but will keep seasonally maintained thereafter.
    Looking to find which JD Subcompact will best suite my needs. First caveat is that I will only be using the property for a few weeks in the Spring and Fall with a 2+ month continuous stay in the summer. Will be hauling lumber, gravel etc. around so a FEL is a must. Also looking to install approx. 1000-1500 feet of fence line so looking at an 3 pt. auger. Some driveway & landscape maintenance will be done and will get a rear blade, rake, or box blade as needs arise. For my pasture mowing and light clearing, thinking of a 5' rotary cutter (light to mid grade). Also considering the JD quick hitch.
    Due to my limited time on property, my initial thought was "get the smallest JD that will get me by," such as a 2305. Helpful guys at the local JD dealer indicated the PTO horsepower will be an issue and suggested the 3032-E as a good entry level model with enough PTO HP plus Hydro., but suitable cost for my "part-time use". BTW, I'm a novice in the tractor/implement arena, but have a fair amount of "mechanical common sense." Thank you in advance for suggestions.
  2. #2
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,025
    texas
    kubota M7040 &m7040
    Default Re: Best JD Subcompact for needs
    Quote Originally Posted by TBJ View Post
    Hello,
    How much you looking to spend? Thats a big factor... Do suggest 4x4,on the smaller units.You usually can find a used 3pt auger somewhere,no need for new for that little of fence. I do think the 3000 series is in the right ball-park,with 5ft shredder somewhere in the 30/35hp range.
    I mean if you got 31grand to spendBest JD Subcompact for needs-jdcab.jpg JD3520
  3. #3
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    Hello,
    My $.02, but I wouldn't want either of those models. The 2305 is too small for your needs and the 3032e just isn't as good of a value, $ for $ I think the Kubota L3800 is more bang for the buck, and I'm known as a Deere guy (take a look at my signature).
    If you want a Deere compact for that amount of land, I would either recommend a 2520 or a 2720 and a zero turn, or a 3x20, preferably with a cab.
    Even for part time use the base model 3032 and the luxury model 3x20 makes a huge difference. From the removable loader to better ergonomics, I think it's a very worth upgrade. If you are doing as much work as you state, although it's not full time, it will be quite a few hours on the seat.
    I would recommend checking out other brands, take a look around, and if your like me, and stuck on JD, then at least you can get some prices for negotiating
    Good luck!
  4. #4
    Super Member murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    6,442
    Ohio
    Kioti DK 40-Massey ferguson 135-Simplicity Conquest
    Quote Originally Posted by Martian View Post
    My $.02, but I wouldn't want either of those models. The 2305 is too small for your needs and the 3032e just isn't as good of a value, $ for $ I think the Kubota L3800 is more bang for the buck, and I'm known as a deere guy (take a look at my signature).
    Good luck!
    Good Post Martian,Check out the competition or better yet used tractors.
    Murph ------------ Sent from my HP laptop
    Nothing runs like a Deere when being chased by a Kioti
  5. #5
    Join Date
    Jul 2011
    Posts
    2,025
    texas
    kubota M7040 &m7040
    Good luck!
    With all the nice JD's out there sure dont see why need to stray off track...
  6. #6
    Silver Member samhudson3's Avatar
    Join Date
    Sep 2011
    Posts
    161
    Central NC, Southern part of Heaven
    John Deere 4300
    Check out the JD 4000 series. I bought a 4300 (35 HP) HST 12 years ago and it's been a great machine. I live on 44 acres, some rolling like yours and it handles everything I've wanted it to do. It was more machine than I needed at the time, but I'm glad I made the investment as I've grown into it.
    Sam
    JD 4300 HST with FEL, bush hog, rear mower, tiller, cultivator/bedder, post hole digger, blade, and a wish list of more.
  7. #7
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    Quote Originally Posted by foreman Etexas View Post
    Seems as though its usually the other way around...
  8. #8
    Join Date
    Jul 2011
    Posts
    2,025
    texas
    kubota M7040 &m7040
    Im just glad you said Kubota and not go way off track:laughing
  9. #9
    Gold Member XSKIER's Avatar
    Join Date
    Apr 2011
    Posts
    319
    Fenton, MI
    '11 Deere 1026R
    Default
    Quote Originally Posted by samhudson3
    I think that 4300 you have would be a 3520 today. When I was shopping, I really liked the 3038e. However it does lack the mid PTO option.
  10. #10
    Join Date
    Sep 2011
    Posts
    161
    John Deere 4300
    Quote Originally Posted by XSKIER View Post
    Made me look it up! It'd be the 4320 now:
    4000 Tractors Series - Product Catalog
    I reckon it's time for me to walk a Deere lot again...
    Sam
Similar Threads
  1. JD QA vs SSQA
    By canoetrpr in forum Owning/Operating
    Last Post: 01-01-2012, 06:33 AM
  2. New Kubota L4240/L4740 vs slightly used JD 4520
    By canoetrpr in forum Buying/Pricing/Comparisons
    Last Post: 09-06-2011, 11:19 AM
  3. Storage rack/protector for JD subcompact
    By jnich17 in forum Build-It Yourself
    Last Post: 03-23-2011, 09:47 PM
  4. Toolcat 5610 vs CUT review
    By radman1 in forum Buying/Pricing/Comparisons
    Last Post: 10-22-2008, 04:07 PM
  5. Kubota Grand L 3240 hst vs JD 3320
    By farmerjim62 in forum John Deere Buying/Pricing
    Last Post: 12-01-2007, 09:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
