Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    New Member
    Join Date
    Nov 2011
    Posts
    24
    Alabama
    Default Is a 4320 big enough??
    Hey guys,
    I have recently bought a small farm (25 acres) and I am thinking about buying a tractor. The things I am planning on doing with it are planting food plots at my hunting camp, pasture maintenance, and feeding round bales. I thought I had my mind made up and was going to buy a kubota MX5100 because everyone says it will do what I need it to and more. Well here recently I have found a really good deal on a John Deere 4320 with a cab. Just wondering what yalls thoughts are on this tractor and if you think it will be able to handle the jobs I need it for. I am pretty sure it will be able to handle the food plots and pasture maintenance, just dont know if it is big enough to handle round bales. This is a big investment for me and will also be my first tractor so I want to gain as much knowledge as possible to help me make an educated decision. Any help will be greatly appreciated.
    Thanks
  2. #2
    Platinum Member Edward. S's Avatar
    Join Date
    Nov 2009
    Posts
    844
    Somewhere
    John Deere
    Default Re: Is a 4320 big enough??
    Just a few questions. It depends on your implement size.
    How big of a bale are you lifting? Rounds? Big Square? Small Square?
    How are your implements are going to be?
    Will you be baling your own hay?
    What type of implements will you be thinking about in the future?
    Will you be getting anymore land?
    Do you have lots of hills on your property?
  3. #3
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    Quote Originally Posted by Pattece View Post
    Hey guys,
    Thanks
    Although the MX5100 has a couple more HP, the Deere has a higher 3pt lift capacity and a nearly the same FEL capacity. For about the same tractor, my money is definitely on the Deere. You get the "comfort" tractor and a cab.
    The specs are very similar, I wouldn't expect one to outperform one greater than the other, but the comfort of the cab would make a long day a lot shorter. If the MX5100 was supposed to handle all your jobs, the 4320 will do just the same.
    My $.02 say the cab is worth it alone, although I've never owned one, it's on my bucket list. I wouldn't be very worried about a used tractor as long as it was taken care of, and those signs are very clear.
    Now the big question is, how much of a price difference between the too and how many hours? If it's very close price and low hours, 4320 is the way to go, high hours, further price MX5100
  4. #4
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    With proper ballast the 4320 will handle most big round bales - certainly based upon the loader specifications. Of the 2 models of loaders available for the 4320; the 400CX is rated for heavier weight.
    IMO - the questions I would consider before plunking down my money - are along similar lines that Edward. S offered - what other kinds of work do you have in mind for the tractor presently and in the future?
    As well, I'd be concerned about the long-term use of the 4320 for hauling round bales. If you're only gonna feed 25 bales a year; no problem - good for the next 20 years. If you're gonna feed 250 bales... well, you might want to rethink how big a tractor you should buy.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  5. #5
    New Member
    Join Date
    Nov 2011
    Posts
    24
    Alabama
    Looking back at my post I see it wasn't very clear... I am new to this but I will only be buying hay.. I am guessing most round bales around here are around 5x6 at best.. My land is fairly flat and I know the 3 pt hitch will do just fine. Just wondering if the front loader will be able to handle the job. kubota price was around $2000 more for a new mx5100 HST but the john Deere is 3 years old with about 400 hours.. I just really like the idea of a cab just did not think I could afford one.. I may be able to purchase another 10 acres that joins it in the future. I plan on getting a tiller and bush hog for now. No big implements
  6. #6
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    Default
    A 4320 would definitely have the capability you require. 3 years old and 400 hours is practically brand new as long as it is in good condition. The cab definitely adds a lot of value and the fact of the Deere being a comfort tractor will make it a lot more comfortable. Whether the new is worth it over a couple hours and a cab can only be decided by you.
  7. #7
    Bronze Member US American's Avatar
    Join Date
    Feb 2011
    Posts
    69
    NW Washington
    JD 4320 Reverser
    I agree that the 4320 will do just fine for those tasks. Deeres loader ratings are supposed to be pretty accurate, so as long as you are under those ratings you should be good. Properly ballasted it is a stout little beast. I LOVE my 4320 and I don't even have a cab.
    JD 4320 Reverser R1s w/ 400x loader
  8. #8
    Veteran Member sunnyside360's Avatar
    Join Date
    Aug 2006
    Posts
    1,520
    Central PA
    JD 3720, JD 4320, Kubota M110X, Kubota ZD1511, Kubota RTV X1100C
    I have a JD 4320 open station tractor with loaded R4's, JD grapple, JD 400X FEL, JD 485 backhoe along with other attachments. There is no doubt in my mind it will handle the work you described. I also have a JD 3720 cab tractor (same cab as 4x20 series) and no one makes a better/nicer cab, imo. I'm not familiar with the capabilities of the kubota model.
  9. #9
    Veteran Member Rockgod's Avatar
    Join Date
    Oct 2010
    Posts
    1,373
    CNY
    JD Cabbed 3720
    Hey guys,
    Thanks
    Can't see what you described as being a problem. Here a couple shots of the 400x in action. 3 trees at once pretty easy.
    Attached Thumbnails Attached Thumbnails Is a 4320 big enough??-100_9768-1024x760-jpg   Is a 4320 big enough??-100_9773-1024x760-jpg
    JD 3720 Premium Cab, 300CX, 59" Front Mt. Blower, 72d MMM auto-connect deck.
  10. #10
    New Member
    Join Date
    Nov 2011
    Posts
    24
    Alabama
    Thanks for all the help and advice guys. I am pretty excited about it. I am going to look at it Tuesday and if everything checks out I plan on buying it.
Similar Threads
  1. Big bass, little pond.
    By N80 in forum Rural Living
    Last Post: 06-13-2010, 09:37 AM
  2. big loads require big trucks
    By deere755 in forum Trailers & Transportation
    Last Post: 04-28-2007, 11:07 AM
  3. dragging big rocks backwards with chain/loader??
    By ccdck20hst in forum Kioti Owning/Operating
    Last Post: 11-14-2006, 10:12 PM
  4. Question about 4320 engine temp
    By ArkLaTexSam in forum John Deere Owning/Operating
    Last Post: 07-18-2006, 08:52 PM
  5. JD 4320 Purchasing Questions...
    By FLDave in forum John Deere Buying/Pricing
    Last Post: 07-07-2004, 11:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
