Results 1 to 9 of 9
  1. #1
    Member
    Join Date
    Nov 2009
    Posts
    29
    Default 2720 Hydraulic Options
    I'm trying to clarify the hydraulic options for the 2720.
    They are:
    Mechanical Diverter Valve -- my understanding is this will divert the curl function to another control, such as hydraulic rippers (if I have a hydraulic box blade)?
    Power Beyond -- Adds ports required for backhoe, etc.
    Rear Hydraulic Outlet Kit -- The description says 'Routes dual mid SCVs to rear of tractor; would this be what I'd want for the top n tilt option? Is this a separate set of spools than the loader?
    Third Selective Control Valve Kit -- Not sure where this one fits unless it would be to have both the curl and ripper function sans the diverter valve.
    Thanks for the help!
    Mark
  2. #2
    Member
    Join Date
    Nov 2009
    Posts
    29
    Default Re: 2720 Hydraulic Options
    Awful quiet in here...
  3. #3
    Gold Member rockshaft's Avatar
    Join Date
    Feb 2012
    Posts
    261
    Sterling, AK
    1026R
    Diverter lets you rob from one function (commonly loader curl) to operate an accessory (such as a grapple)
    Power beyond routes hydraulic flow to the rear of the tractor for use with backhoe (or potentially a valve block you might select)
    Rear outlet kit will work for top n tilt functionality, but I believe in doing so you rob the loader control (mid SCVs) when rears are in use.
    3rd SCV allows you to operate a stand alone valve for top n tilt (or other accessory) independent of mid SCVs
    Don't take my word as gospel! Others should chime in if I'm wrong with anything here.
    Quote Originally Posted by MFortie View Post
    They are:
    Mark
  4. #4
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,761
    South West MI
    John Deere 2030, John Deere 6415
    I'll expand on what rockshaft posted.
    Power Beyond is for something (like a backhoe that has it own hydraulic valve(s)) or as rockshaft said if you want to add a set of valves, PB will let you power them.
    Rear outlet kit MOVES the outlets from mid positon to rear. You do not want this if you have a loader. Unless you want to run your loader hoses to the rear and have the outlets there for when the loader is off.
    Third SCV, One & Two will be be mid mount for loader unless you opt for rear outlet kit. Third will be additional. More is better. you could run hoses from it to a grapple (that's how my 2030 grapple is hooked up) or use it for ONE function hooked to the rear.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  5. #5
    Member
    Join Date
    Nov 2009
    Posts
    29
    Quote Originally Posted by Zebrafive View Post
    Ah; that's kind of input I was looking for. Thank you!
    I didn't realize the the rear outlet kit MOVED the ports (which is exactly what I needed to know!)
    So, if I wanted to run top n tilt, I'd need a set of valves (spools) with controls for the cylinders -- or use the rear outlet kit and use the loader spool(s) and control(s)? But then I'd have to swap hoses from the loader to the box blade, correct?
    I'll definitely get the third spool as I want to have hydraulic control over the rippers in the box blade (and possibly a grapple down the road on the front).
    Other uses are a backhoe (hence the PB kit), tiller, rotary mower, & auger at this point. Someday maybe a log splitter and a sprayer might be nice, but that's about it. No need for snow equipment around here! LOL!
    Thanks again,
    Mark
  6. #6
    Join Date
    Jun 2006
    Posts
    130
    Rockford MI
    If you order the 3rd scv I believe you will need the power beyond also. Also the rear outlet kit extends the loader connections to the back by plugging into the loader ports.
    I think you would have to remove the loader to disconnect the lift arm hoses otherwise I doubt you would get it re-connected. Just saying your loader disconnects stay where they are and the rear hoses plug in to them the same way your loader hoses do.
    Myself and many others have purchased the pb. kit and then an aftermarket spool valve and saved considerable money. There are lots of pictures on the site detailing how people have done this.
  7. #7
    Join Date
    Nov 2007
    Posts
    130
    Rochester NY
    JD 2320
    On my 2320 I added a 2 spool valve from surplus center inline with my power beyond to get an additional 2 sets of outlets for my snowblower chute / rotation, and top /tilt when I decide to get it. You do not need the power beyond to do this and here are a couple of threads here explaining how to do it. Basically you remove 2 plugs on the loader valve, and connect another valve inline.
    JD 2320 w/ R4's, 200CX w/ 61" bucket, 46BH w/ 16" bucket, 62D MMM w/ mulch kit, Imatch, Ballast Box, Frontier BB 2060, Frontier 1060 Landscape Rake, Frontier Pallet Forks, Frontier SB1154 Snow Blower, Meyers 6.5 TM snowplow, Markham 48" Grapple, Trac-Vac 854
  8. #8
    Join Date
    Apr 2011
    Posts
    551
    John Deere 2720
    I just purchased a 2720 and waiting for it to be delivered. This discussion has been very helpful as there are not a lot of good photos out there describing these features.
    I do not have a loader. I will be using a front-mount snow blower which will use all the hydro ports for raise-lower and chute rotation. I would also like to get a hydraulic top link at some point to use with my rear blade. I originally thought I just wanted the rear ports but it sounds like a better way to go would be the 3rd SCV, albeit at more cost.
    Obviously I would like to have the hydraulic top link in addition to the blower/chite control but I have to decide if it is worth the extra cost.
  9. #9
    Gold Member newt92's Avatar
    Join Date
    Dec 2007
    Posts
    351
    Secor Illinois
    John Deere 2520 and 2305
    It consists of 4 hoses that plug into the mid position and go to the rear outlets.. If you wanted to run the loader, you just unplug the rear kit and plug the loader into the mid ports.. The rear outlet kit hoses stay with the tractor, just tie them up under the tractor.
    2007 JD 2305, 2008 JD 2520 w/200cx loader, Harbor Freight quick hitch, homemade pallet forks, 5' KK tiller, 5' KKxb disc, 4' landpride pulverizer, Frontier RB1072 blade, homemade 5 1/2' lawn roller at 3500lbs, 2005 John Deere 797 w/60" deck, 2009 John Deere 997 w/ 72" deck, 2005 JD HPX Gator w/power dump, 1998 Toro 455D 10.5' deck!
Similar Threads
  1. Oil & Fuel Motor Oil as the Hydraulic Oil in Power Trac
    By DieselPower in forum Power Trac
    Last Post: 12-11-2014, 08:45 PM
  2. Sea Foam in hydraulic sys
    By J_J in forum Hydraulics
    Last Post: 04-22-2012, 12:54 PM
  3. Stripped hydraulic fitting threads - options?
    By cgraham in forum Parts/Repairs
    Last Post: 06-24-2007, 07:23 PM
  4. Hydraulic problems
    By EMail4U in forum Hydraulics
    Last Post: 10-02-2004, 09:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
