sjhulsmn
- Joined
- May 31, 2011
- Messages
- 17
- Location
- St. Joseph, MN
- Tractor
- JD 3720cab w/300CX loader, JD 955 w/70A loader,, JD737 zero-turn
For those of you that have Artillian pallet forks, do you like them or do you wish you had another brand of pallet fork? Also, for those of you that are familiar with Artillian pallet fork products, what is the advantage of the Cascade fork vs. the standard fork? Also, what is the difference between standard and full taper forks? According to the Artillian web site, the Cascade forks are heavier then the standard forks and are made in the USA. I've have a JD 1070 with 440 loader that I'm thinking of getting a set of forks for. One of my main uses for forks will be removing rocks from my field. Some of these rocks weigh between 300 to maybe 700 pounds. Any input is appreciated.
