Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Jul 2003
    Posts
    108
    Middle GA
    JD4310
    Default 5075M or 5085M
    I am going to sell my cab 4720 tractor and order me either a 5075M or 5085M. I have about 60 acres of land that I want to do some small scale row crop farming. Beside a hp and price difference, is there anything else that stands out between these 2 tractors?
    Smitty
  2. #2
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,424
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Default Re: 5075M or 5085M
    someone mentioned differences in the hydraulic valve option where the 5085M had more options, don't know myself.
  3. #3
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,756
    South West MI
    John Deere 2030, John Deere 6415
    The main difference is the engines. The 5075M has a 5 cylinder 3.0 liter turbo diesel. It does not have wet sleeves they are cast in the block. The 5085M has a 4 cylinder 4.5 liter turbo diesel. It has the wet sleeves, individual replaceable cylinder liners. This model is 10HP more. There are other versions of the 4.5 liter diesel pushing out a lot more HP. It's 50% larger displacement engine, 4.5L vs 3.0L.
    The 5085M has approximately 4 gallon per minute higher hydraulic pump volume. Cab version will hold 6 gallons more fuel and weigh about 600lbs more than the 5075M.
    You can get the same transmissions and hydraulic valves on both.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  4. #4
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    Zebrafive pretty well nailed it. My vote goes for the 5085M...
    I would try and keep the 4720 if at all feasible, the CUT's are much nicer to operate than the larger tractors with their HST transmissions.
  5. #5
    Super Star Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    10,434
    Giddings, Texas
    JD 4310,JD5420
    Have you called your dealer to see what the price difference is between them? I'd go for the bigger engine, but right now I'd be doing good to afford a 4 hp harbor freight engine.
    One of these days....One of these days...
  6. #6
    Super Member
    Join Date
    Dec 2007
    Posts
    9,873
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    My 5520 is a 276 cu in, 86 HP, 4.5 and it is a much more stout than the smaller tractor. It is a real mass of machine that is good on fuel and is as good at tillage as it is at tip-toeing through the corn rows. I plan to keep as long as I am around.
    May I be the kind of person my dogs think I am,
  7. #7
    Join Date
    Jul 2003
    Posts
    108
    Middle GA
    JD4310
    Thanks for all the replies guys. Just what I was looking for. I am going to go with the 5085M. As soon as I sell my 4720.
    Smitty
  8. #8
    Join Date
    Aug 2010
    Posts
    3,756
    South West MI
    Good choice!
  9. #9
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    2,175
    W. Central Louisiana
    JD 5083E; JD 5085M; NH TN70A; Ford 2600
    Quote Originally Posted by Zebrafive View Post
    Yep, just the engine and hydraulic output.
    Smitty,
    Just a few suggestions.
    Go with the 16x16 Power Reverser transmission option. You'll be glad you did.
    Radial tires. Much better ride plus greater ground contact. Really helps put all that hp to the dirt.
    540/540E PTO is a must. Most of the things you do with that tractor can be done in 540E mode. That's 1700 rpm -vs- 2100 rpm. Big fuel savings. (just looked at JD website and saw that the 540E is now standard equpiment)
    Electrohydraulic 3 pt hitch. You'll wonder how you ever got by without one.
    Go ahead and order the outside mirror kits. The one in the cab is useless.
    '12 JD 5083E Cab MFWD FEL
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    Vermeer 504R round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Krone 5.52 Tedder; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '01 Peterbilt 379.
    "I've come to the point in my life where I can't remember if I've lost my horse or just found a rope."
  10. #10
    Join Date
    Jul 2003
    Posts
    108
    Middle GA
    JD4310
    Thanks for the suggestions. I like the 16x16 power reverser transmission and definitely love the 540E pto. I want some wide radial tires, something similar to the ones I see on some of the European models (5100R series).
    5075M or 5085M-5100r-jpg5075M or 5085M-john_deere_5100r-jpg
    Smitty
Similar Threads
  1. 5075M...coming soon!
    By larryinparks in forum John Deere Owning/Operating
    Last Post: 06-16-2013, 03:51 AM
  2. Price Check 5075m
    By jayhawkhusker in forum John Deere Buying/Pricing
    Last Post: 06-28-2012, 01:34 AM
  3. New 5075M is at the dealer's!
    By AKfish in forum John Deere Buying/Pricing
    Last Post: 05-10-2012, 11:06 PM
  4. Price Check Price check on 5075M
    By mechatgsk in forum John Deere Buying/Pricing
    Last Post: 06-17-2011, 02:51 AM
  5. Comparison JD 5075M vs NH T4030
    By audiski86 in forum Buying/Pricing/Comparisons
    Last Post: 07-03-2010, 06:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
