Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
  1. #11
    Join Date
    Dec 2009
    Posts
    1,622
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    Default Re: 2013 5065e or 5075e
    As far as I know the power reverser trans is only available on the cab models. The 5045e-5075e open station are just like the previous ones, but tier 4. Based on what the dealer told me, all they have done to make those particular models tier 4 is fiddle with the timing and fuel delivery, and bump the price up (they are also harder to start when cold). I was looking at 2013 5045d's and decided to go used instead. It's amazing how much easier my 5203 starts vs my fathers 5045e (2011 model, tier 3).
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  2. #12
    New Member
    Join Date
    Nov 2012
    Posts
    11
    Murfreesboro, tn
    None yet
    Default
    Quote Originally Posted by Verticaltrx
    The power reverser will be available on the open cab models as well as my dealer was able to build the quote, just won't be shipping until around April. The other option I have is a 2007 5425 power reverser with 100 hours for 30,500. I am just A little worried that it has been sitting for to long with out any use..
  3. #13
    Join Date
    Apr 2004
    Posts
    617
    Just purchase a 5045E and dial the fuel flow up to 75.
  4. #14
    Gold Member dntfxr's Avatar
    Join Date
    Aug 2007
    Posts
    284
    north Louisiana
    Deere 2040, Kubota b7100
    Default
    Good to know the new 5000E's will have the power reverser option.
    Btw, I know the fuel delivery is the main difference between the different HP, but does anyone know exactly how to adjust it?
    '76 John Deere 2040
    '94 Kubota B7100 mfwd HST -"Little Bull"
  5. #15
    Veteran Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    1,385
    Central MA, Lakes Region NH
    Kubota L4610 and John Deere 410
    Quote Originally Posted by dntfxr View Post
    Although BuickandDeere makes it sound easy, from what I've read on here about the 4x20 series is that it's virtually impossible to economically boost the power to more hp.
    There is a lot more to it than turning a set screw. If you need/want more power, spend the money up front and be done with it. Not to mention, you'd be voiding the warranty on your brand new tractor, plus, who's to say you wouldn't mess anything up in the attempt to upgrade the power, then it ends up costing you more than if you just bought the tractor you should have bought in the first place.
    Kubota L4610 and John Deere 410 - WR Long 64" Grapple (best attachment ever!) QA front forks, rear forks, Brown 472 HD Rotary Mower, homemade 3 pt log splitter, Land Pride rake/blade combo, Land Pride HRL 3578 box blade (Hydro scarifiers), Shaver SC50 3 pt. Stumpgrinder, FitRiteHydraulics TnT, 6" Vermeer PTO Chipper (Hydro feed), 2 bottom Disc Plow, Ratchet Rake
    Rear Remotes Install
    How to search TBN
  6. #16
    New Member
    Join Date
    Nov 2012
    Posts
    11
    Murfreesboro, tn
    None yet
    Default
    Well... I told the dealer to get a 2012 5075e setup for me with 553 gel and the mx8 cutter... While it would have been nice to be able to get the 5045e.. I found no detailed info on what is involved to make a 45 in to a 75, while I do understand that some of it involves fuel flow, I would be surprise if that is the only change. Seems like there would need to be some turbo tuning, and some timing changes.
  7. #17
    Veteran Member pclausen's Avatar
    Join Date
    May 2008
    Posts
    1,296
    Nelson County, VA
    JD 5085M, JD 1445, JD GT235, JD LT166
    Good choice! Yeah, I'm quite certain that there is a *lot* more to it than just turning some "set" screw...
    Now, if they came out with something list "LS1 Edit" like they have for the Chevy small blocks, where you can edit the fuel delivery curve, timing, etc, then we might be talking! Or something like the Predator for the Chevy Duramax engines where you can do the same thing by selecting from 4 different power levels, then we might be in business, but I just don't think the market is big enough for a 3rd party to get into that game. In some ways, diesel engines are easier to tune for more power than gas engines since you don't have to maintain a certain air to fuel ratio and can simply increase the amount of fuel delivered for more power, but you have to watch exhaust temps and turbos adds a whole other dimension to things that can go wrong when too much fuel is being delivered!
    I run the predator on my 2002 Duramax truck, and I can tune it to where the Allison transmission start to slip and goes into limp mode. You are playing with fire for sure however.
    That said, it would be cool to be able to program your factory fresh tractor for power that that crazy Swede that put a turbo on his tractor and can go 60 mph down the road and make rooster tails in the field at will.
    JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods BH1050 Backhoe, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Maschio H205 Tiller, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
    2002 Silverado Duramax 3500 Crew Cab LT 4x4
    BigTex 22.5K 25' Gooseneck Trailer
  8. #18
    Join Date
    Dec 2009
    Posts
    1,622
    S. W. Virginia
    The open station 5e series are still all mechanical injection, no electronics whatsoever. In theory it is possible to take a 5045e and 'turn it up' to a 5075e. With that said, I'm not sure the practicality of it as the EPA has done everything the can to make sure you can't fiddle with the injection pump. I would hope there is still some adjustment in the pump, but it wouldn't surprise me if more fuel = buying a different pump. Also, there are other changes that go along with, or are used in lieu of turning up the fuel. I think to go from the 5045e to 5055e it is just a change in timing, then to go to the 5065e its a change in fuel delivery. Not sure what the 5065e vs 5075e change is, but it might involve the boost pressure, etc. Sometime I hope to get a shop manual for these tractors and see if I can figure out what the real difference is. Regardless, buying the right size from the start is sound advice, and I wouldn't go tinkering on a brand new tractor anyways.
    The 5075e and MX8 will be a nice combo.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    JD 265
  9. #19
    Join Date
    Apr 2004
    Posts
    617
    The injector tips size does change along with pump elements.
    Electronic common rail systems are easy. Just install higher flow injectors to use with the stock timing.
  10. #20
    Elite Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    4,882
    Kasilof, Alaska
    JD 5075M; JD 110 TLB; Ford Ferguson 9N: JD X300R
    Quote Originally Posted by buickanddeere View Post
    No such thing as a "Free Lunch"! Horsepower or cheeseburgers... you get what you pay for! Much discussion here (and other brand forums) on the 4000 series (and some on the cab model 5083e) of jumping the horsepower with a little "tweak" on the injector pump.
    A detailed review of the parts listing's (pump, turbo, injectors) for the different Hp rating on the 4000 quickly illustrates that it's not JUST a set-screw on the pump. It's a whole lot more!
    'Course, I don't know about you - but, if I'm gonna buy a NEW tractor - why, why would I trash the warranty right off the dealer's lot??!?
    Pony up for those extra horses.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
Similar Threads
  1. Price Check Price check on 5065E and 5075E
    By rod330 in forum John Deere Buying/Pricing
    Last Post: 04-24-2013, 07:32 PM
  2. 2013 price changes- 5065e
    By Rmd8136 in forum John Deere Buying/Pricing
    Last Post: 10-03-2012, 10:32 PM
  3. 2013 5075E Cab
    By trook in forum John Deere Buying/Pricing
    Last Post: 09-23-2012, 08:22 PM
  4. Changes in MF 2013 line
    By Mike476 in forum Massey Ferguson Owning/Operating
    Last Post: 06-07-2012, 03:15 PM
  5. JD 5065e vs JD 5075e
    By JD BUCK in forum John Deere Owning/Operating
    Last Post: 07-28-2011, 12:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
