Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Silver Member MWRR's Avatar
    Join Date
    Jan 2011
    Posts
    146
    East Central Illinois
    John Deere 5105M & IH Farmall 544
    Default Re: John Deere M vs. E series
    This topic has been kicked around a couple of other times on here. My only suggestion would be to put both tractors side by side and compare. There is a quite a bit of difference. Then drive both tractors.
    Best of luck on your decision......been there and done that, lol.
    MWRR
    Illinois, 180 acres, 80 acres hay, cattle, JD 5105M,IH-Farmall 544, Kuhn 700 GMD HDII, Case 580B, JD 535 Baler, MF 124.
  2. #22
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Many of us have wrestled with the same question - questions! I remember questioning if some of the things that I wanted weren't really... really "frilly" things that I could live without anyway. Air seat (couldn't get it on the E's then) 16 speed versus 12 speed tranny, ePto (N/A on the early E's), etc. etc.
    What finally, finally pushed me into a M was the electro-hydraulic 3pt hitch. With those remote fender mount controls! That's it! I'm usually by myself hooking and unhooking attachments and being able to stand on the ground and raise and lower the 3pt while making those final adjustments..
    That's what sealed the deal for me.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  3. #23
    Join Date
    Feb 2009
    Posts
    1,356
    NC
    There's a 5065M 2WD here on the farm. There's more to it than bells and whistles IMO. The location of the majority of the controls is one of the key factors when I helped my wife and son pick out the M over the E. After watching the show on RFD-TV on the E I can see even more reasons for the M over the E, it appears that the seat back on the E has no adjustment and some other differences, maybe the air seat option gives you the seat back adjustment. The main thing is it has our wanting to get in the tractor and stay in it all day if needed. We put a JVC radio in it and he can connect his iPhone to it and listen to whatever he wants and if the phone rings it mutes the radio and rings through the radio, $70 is much cheaper than JD's $600-700 radio. As far as where they're made the I was told the 5M 2WD has an India made front axle, the Transmission is from China, the hydraulics are from Brazil, the engine is marked Mexico, the cab and wheels are marked USA.
    '18 Kioti CK2610 HST w/FEL
    '12 John Deere 5065M /cab
    '10 Kubota L3940 w/FEL
    '09 JD X720
    '91 CaseIH 5140 Maxxum w/cab
    '78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
    Youtube Channel: https://www.youtube.com/channel/UCPA...NYlQIu7snVQ2nw
  4. #24
    Join Date
    May 2009
    Posts
    942
    South Mississippi
    2008 John Deere 5303 MFWD
    Default
    Posted a thread myself on this issue but considering the 5065E vs 5065M. Wound up with a 2008 5303 which is the equivalent of the 5065E. I have been very pleased and have found myself trailering it several times a year and have been glad to have the weight less. With the 4WD option I have not had traction issues like I did with my previous 2WD 5105. In my opinion unless you are a daily user/farmer or just want the best available and money is no object, you will be hard pressed to find a better deal going than the E series. If you get the appropriate horse power needed and aren't working really heavy ground engagement equipment I am not sure from a function perspective you will be able to find anything lacking on the E series.
  5. #25
    Platinum Member corey9212's Avatar
    Join Date
    May 2010
    Posts
    740
    Red Deer County, AB
    2015 John Deere 3046R
    Default
    I know this is kinda late in this discussion but when I asked the dealer about the difference in the E series to the M series he said the E is for economy and the M is for Luxury (Think of it as Mercedes, lol.) he said both are great tractors but the E is for the people who don't need the bells or whistles or are on a tighter budget.
    Either way you will be happy with the 5 series of tractor fuel economy it out of this world (12 hours if mowing plus a couple hours of heavy loader work, plus an hour of discing and an hour of harrowing and only burnt half a tank, that's LESS than 2 gal/ hour.)
    - 2015 John Deere 3046R
    - H165 Front End Loader w/73" HD bucket
    - 72D Auto Connect MMM, John Deere 375A Backhoe w/18" bucket, John Deere 59" Front Mount Snowblower, Frontier DH1296 8' Disc Harrow, Frontier SS2067B Poly Broadcast Spreader, Frontier AP12F Pallet Forks, John Deere 3PT Trailer Mover, Maybridge 12' Drag Harrow, 55 Gallon Spraytech 3PH Sprayer, 90 Gallon Water Carrier, 3 point bale spear
  6. #26
    Platinum Member Edward. S's Avatar
    Join Date
    Nov 2009
    Posts
    844
    Somewhere
    John Deere
    Quote Originally Posted by corey9212 View Post
    Strange because I can only get 12 hours out of a tank of fuel on my 5085M. But I'm usually on the road and hauling stuff with those hours. Usually throttle is wide open. Got only 110 hours on it About my fluid leaking from under the cab, it was a steering valve.
  7. #27
    Join Date
    May 2010
    Posts
    740
    Red Deer County, AB
    Default
    Quote Originally Posted by Edward. S View Post
    Yeah the most my rpm's get is 1700rpm so far (just enough to run the PTO in economy mode.)
  8. #28
    Silver Member bglz42's Avatar
    Join Date
    Mar 2009
    Posts
    231
    DIckinson, Texas!
    2013 John Deere 5083E
    We are very happy with our 5083e. We were definitely on a budget, so I would not even let myself LOOK at an M, LOL!
    Humble Camp Peach Farm
    2017 Mahindra 2538
    1966 Massey Ferguson MF150 Diesel High Clearance
  9. #29
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Two gallons an hour is about what I have averaged over 155 hours with my E from brush hog work to plowing snow etc. It certainly does two dollars worth of work for a dollars fuel used.
  10. #30
    Join Date
    Dec 2012
    Posts
    83
    Western NC
    green
    Default
    I like my new 5085m more than any tractor I've owned. The power reverser has a lot to do with it, but the triple remotes, a smooth shifting tranny, a wider platform with well laid out controls, good anti sway bars, low mounted fuel tank, 540 E option and yes, even the improved emissions.
    Don't get me wrong, I really like my 6330, and the 5085 M cannot compete on heavy tillage
    jobs. I tried pulling my 7 shank chisel plow with the M for fun, just to see what it could do and no way.
    Good of hear about the batwing mower bogging it down. This is our small utility tractor, but it is sized up a notch to give me some options if the 6330 breaks down.
    My only complaint so far is they changed the side of the seat belt. Not a big deal
    But old habits die hard. And there is little room on the fender to sit when training operators.
    *JD 5085M *JD 6110 w 640 loader *JD 6330 *AC F2 Gleaner *Ford 7.3 Powerstroke x 4
Similar Threads
  1. JOHN DEERE 5m SERIES
    By DJT74 in forum John Deere Owning/Operating
    Last Post: 06-16-2013, 11:40 AM
  2. John Deere 6m Series
    By csm1th in forum John Deere Buying/Pricing
    Last Post: 03-09-2013, 12:29 AM
  3. Snowblower for John Deere 100 series?
    By GreenRules in forum John Deere Lawn & Garden
    Last Post: 07-06-2007, 10:23 AM
  4. New 4000 TEN Series from John Deere
    By Muhammad in forum John Deere Buying/Pricing
    Last Post: 06-01-2002, 06:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
