Results 1 to 5 of 5
  1. #1
    Join Date
    Jun 2004
    Posts
    185
    Northeast Texas
    John Deere 5325 4wd, Kubota B7500 HST
    Default John Deere 1530 Injector Pump Leak
    Hi All,
    I've searched the internet using google and tried to search this site without any luck. So, I came to the experts to ask the question directly.
    We have a 75 John Deere 1530. Fuel is leaking from the injector pump. We can get it rebuilt in the 700 - 900 dollar range, but I wanted to see if there might be a cheaper solution to the problem.
    Can these be rebuilt DIY?? Is there an aftermarket supply for these less than $700 dollars? Anyone had a leak they've actually fixed without rebuilding?
    Any and all information you have would be helpful. I want to make sure there isn't a rebuild kit available or some other alternative before we lay out the bucks to have it rebuilt.
    Thanks.
    Kubota B7500, 302 FEL, 60" MMM. John Deere 5325 4wd, 542 FEL.
  2. #2
    Join Date
    Jun 2004
    Posts
    185
    Northeast Texas
    Default Re: John Deere 1530 Injector Pump Leak
    Any duct tape and bailing wire repairs out there? Are there any epoxies out there that might work? I'm really just wanting to get the fuel leak stopped the cheapest way possible.
  3. #3
    Join Date
    Oct 2002
    Posts
    813
    Pomfret,Connecticut
    yanmar 336d w ldr,Cub,many attachments
    do you know where the leak is coming from on the pump ? If its a fitting or fuel line should be relatively,is the pump clean ?
  4. #4
    Join Date
    Jun 2004
    Posts
    185
    Northeast Texas
    It looks like it's coming from where one of the fuel lines exits the injector pump. I'm not sure if those things are pressed in or have some kind of o ring seal?? I guess we'll have to take it apart and take a look. I'll update the thread when we can figure out exactly where it's leaking.
  5. #5
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Quote Originally Posted by ocaj11 View Post
    Do you have a picture? I would caution you about taking anything apart or removing the pump without following the proper steps. You can usually remove the fittings without disturbing the actual pump and settings. Not familiar with the 1530 but pretty sure you can get new seals for the injector lines in a kit form.
    Depending on the s/n and pump type you should be able to get new washers to seal up this leak as mentioned above, here is a pic from Deere parts on the 1530.
    Attached Thumbnails Attached Thumbnails John Deere 1530 Injector Pump Leak-rwp5583________un01jan94-gif
Similar Threads
  1. Hydraulic pump leak - John Deere 445
    By Allan Robinson in forum John Deere Lawn & Garden
    Last Post: 04-10-2013, 09:07 AM
  2. NEED A USED INJECTOR PUMP FOR John Deere 750
    By rich386 in forum Parts/Repairs
    Last Post: 05-08-2012, 03:40 PM
  3. John Deere 650 injector pump
    By KubotaSam in forum Parts/Repairs
    Last Post: 05-05-2012, 08:35 AM
  4. John Deere 5310 injector pump woes?
    By exiled in forum John Deere Owning/Operating
    Last Post: 02-07-2008, 08:23 PM
  5. John Deere 5310 injector pump woes?
    By exiled in forum Parts/Repairs
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
