Results 1 to 10 of 10
  1. #1
    Platinum Member Notforhire's Avatar
    Join Date
    Nov 2011
    Posts
    853
    Southwestern Virginia
    JD 5055E
    Default Canopy for 5055E
    I'm thinking of getting this John Deere Tractor Canopy, John Deere Tractor Canopies, John deere Tractor Sunshades, John deere tractor roofs, JD Tractor sunshade, Canopies John deere, Sunshades John Deere made from fiberglass canopy. According to the listing it has a liner with sound absorption characteristics.
    Anyone who has installed canopys; can you tell me if there was an increase or decrease in the noise level from the open station?
  2. #2
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Default Re: Canopy for 5055E
    I am 99% sure that is the same brand canopy I had on the JD 2355 and now have one on the kubota.
    Originally the Deere had the factory canopy that looked just like the top of the Sound Guard cab. After it got beat up I replaced it with one like the picture in your link. IMO neither canopy made a difference in the noise level while operating the machine.
    The Kubota came with the canopy installed so I have nothing to compare it to.
  3. #3
    Join Date
    Nov 2011
    Posts
    853
    JD 5055E
    Quote Originally Posted by DT86 View Post
    Thanks for the info. I presume you are happy with the canopy, since you bought another like it.
    Years ago I had a tractor with a homemade plywood canopy. It kept me dry in the rain, but it reflected all the engine noise. It was like being in a drum. I just don't want a repeat preformance.
    Best, Bill
  4. #4
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,197
    Branson, Mo.
    Kioti DK35se Hydrostat
    I have one of these and like it.. it is steel, with a noise liner, I could not tell any difference in the sound with or without it. I bought it from the dealer. It came in about 2 or 3 weeks. and the dealer and I installed it at my house. If I remember right it was only a $200. He said he gave it to me at his cost as a sweetner on the tractor deal. I dunno what they cost, but it is a good one.
    Wells Ag Company - Tractor Canopies
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  5. #5
    Join Date
    Nov 2011
    Posts
    853
    JD 5055E
    Thank you James I'll check it out.
    Bill
  6. #6
    Join Date
    Jun 2009
    Posts
    28,197
    Branson, Mo.
    Canopy for 5055E-branson-20120417-00021-jpgCanopy for 5055E-branson-20120417-00027-jpgHere is a couple of photo's right after it was installed, it is just a sheet of bent steel and a steel framework with the noise liner pad, but it works well, and I have hit several smaller branches with it without any damage.. not saying though that hitting a big one would not wad it up, but I think they all can break or bend if you hit something hard enough.
    James K0UA
    James K0UA
  7. #7
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Default
    Yes, I am happy with it.
    Here is what you can expect as far as sound dampening goes.
    Canopy for 5055E-image-2015140339-jpg
    Canopy for 5055E-image-3575109577-jpg
    It doesn't look like much but I guess it does its job.
    One thing I did on the Deere to make it more enjoyable to drive was to turn the exhaust outlet away from the canopy. That helped a lot.
  8. #8
    Join Date
    Nov 2011
    Posts
    853
    JD 5055E
    Quote Originally Posted by k0ua View Post
    James K0UA
    James, I sent Wells an e-mail I'll let you know what they have to say, when they get back to me.
    In your opion, is their canopy stiff enough to mount lights on? I'm interested in mounting two forward facing and two rearward facing flood lights underneith. Opions?
    Best, Bill
  9. #9
    Join Date
    Jun 2009
    Posts
    28,197
    Branson, Mo.
    Quote Originally Posted by Notforhire View Post
    Best, Bill
    I believe it would be Bill, It has a pretty good right angle frame up under there.. look at the photo's I uploaded. and see what you think. but I believe it would be.
    James K0UA
    James K0UA
  10. #10
    Join Date
    Nov 2011
    Posts
    853
    JD 5055E
    Thank you all for the photos. It's a big help!
    Bill
Similar Threads
  1. Canopy for 5055e
    By fieldman12 in forum John Deere Buying/Pricing
    Last Post: 04-21-2013, 01:39 PM
  2. New(ish) 5055e
    By loxahatcheeman in forum John Deere Buying/Pricing
    Last Post: 03-03-2013, 03:57 PM
  3. New 5055E
    Last Post: 12-15-2012, 09:29 AM
  4. New JD 5055e
    By RickS in forum John Deere Buying/Pricing
    Last Post: 10-16-2011, 02:31 PM
  5. 5055E 4WD FEL
    By scrimshaw33 in forum John Deere Buying/Pricing
    Last Post: 10-12-2010, 03:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
