MorningViewStables
I can't believe you guys are operating loaders without ballasts. The Manual for the H310 specifically states minimum ballast is just over 4000 lbs with more than half on the 3 point and the rest on the rear axle (tire fill and or wheel weights). OMW55317. I have a 5075M with H260 and carry 2200 lbs on the 3 point and according to the manual, I should have additional 900 on the axle and 700 lbs more without the cab. As for the LSS, I don't have one, but it is used for transport only over rough terrain. It is to be turned of for digging and back dragging. You be the judge on how you will use your loader.
http://www.tractorbynet.com/forums/attachments/attachments/364575d1394392334-ballast-photos-ballast-010.jpg
