Doc, I have not found a need to use more than one floor jack to remove/install the belly pan. If it is centered roughly it is easy to handle
I will try it with one jack the next time I need to take the pan off.
Doc,
When I ordered mine in 2005 I added all the extras except a radio. Don't ever listen to them anyway.
I bought my 110 used, it came with most options:
Front Loader 2 function Hydraulics
Rear 3 function Hydraulics
7 Function DipperStick
LVB25657 Hydraulic Clamp / Thumb
LVB24967 Backhoe Bucket Quick Coupler
LVB25354 Rear Work Lights Kit
AR87167 Engine Coolant Heater
LVB24904 Hydraulic top and Tilt 3-Point Rear Hitch
The options that i have installed:
LVB25424 Tractor rough service Protection / belly pan kit
LVB25356 Backhoe stabilizer cylinder guards
LVB25359 Tractor draw-bar hitch assembly
LVA12133 Solid rubber stabilizer foot pads: (4 Required)
LVB25426 High-intensity strobe warning light
The options that I want to install:
AR94493 Transmission oil Heater
LVB25353 Slow Moving Vehicle Kit with Cup Holder
LVB25067 Adjustable mirror kit
LVB25360 Tractor horn warning kit.
I have the horn kit, I'm having a hard time trying to find where to plug in the wiring harness !!!!
