Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default 3020 diesel $$$$$
    I put Down on a 3020 Diesel Deere, I'm paying 7700 and delivered to my house, it has 4800hrs. great tin and tires at 80 percent, this is a '66 model. going to use for snow blowing and light field cutting. will be kept inside and plan on having heater to plug it in. is this tractor in good condition worth it??
  2. #2
    Super Member
    Join Date
    Dec 2000
    Posts
    6,737
    JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
    Default Re: 3020 diesel $$$$$
    John,
    I wouldn't say it's not worth it but you're not getting any great deal on it. The 4020's, considered one of the best jd ever put out, go for around 6000-8000 around here. If it's in good shape like you say though it's not a bad deal either. Probably like paying high book for a car, at least in relation to the Iowa area.
  3. #3
    Gold Member
    Join Date
    Apr 2001
    Posts
    262
    Vermont
    Kioti DK45S w/ Backhoe
    I have a book that lists 4 3020 models in 1966...
    Model CuIn Type low-high
    3020 227 gas $3300-$6300
    3020 270 diesel $3600-$6700
    3020 HC 241 gas $3700-$6900
    3020 HC 270 diesel $4000-$7500
    The "HC" stands for "High Clearance"... All have about the same PTO hp (70.5-71.5).
    This is a new book (for me) and I'm not sure how accurate everything is!??! This should give you an idea...
    Billboe
  4. #4
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Well John,
    You put a deposit down, so the "horse is already out of the barn", but you asked and you shall receive...
    JD3020 2WD, Mfr. 1964-72, 4 cyl Gas/LP/Diesel,227/241/270 cid, 64/70 PTO HP, 7500-7800 lbs., Last factory list prices $6780./$9450 HC.
    Low/Avg/High - Avg. Auction Pricing
    $1,900/5,100/8250.
    John, the bottom line, if you love her... then keep her.
    Good luck John.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
