Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Oct 2004
    Posts
    115
    Western NY
    John Deere 4410
    Default 4410 Wheel weights VS. loaded tires
    One dealer who is quoting me on a new 4410 says I'm better off with the wheel weights than filling the tires with water and anti freeze. My Kubota has had loaded rear tires with calcium and water for 23 years and the only problem has been if you put a stick thru the tire you have to wait for a tire man who can field repair a loaded tire. We got a great guy not to far from us but some day he's going to retire, then what? Anybody got an opinion about which is better?
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: 4410 Wheel weights VS. loaded tires
    I have mine filled with windshield washer fluid. I then add the ballast box. If ever need more, I would add higher sides to the ballast box (borderline doing that now). Then, if needing more, I would put on the wheel weights. But I don't like the looks of wheel weights. Just an opinion from here.
  3. #3
    Gold Member
    Join Date
    Jun 2003
    Posts
    333
    Michigan
    I prefer loaded tire for the lower center of gravity, plus it's more weight than wheel weights AND I can always add wheels weights at a later date myself if I want them. I don't feel like loading tires at a later date, though (or ever [img]/forums/images/graemlins/smile.gif[/img] ). My tires are loaded with RimGuard www.rimguard.biz and am very happy with the results. The tractor is very stable when mowing ditches.
  4. #4
    Veteran Member GreenRules's Avatar
    Join Date
    Apr 2002
    Posts
    1,446
    Casco, Maine
    New Holland t5040 JD 4110, 110. 212, 325, GT 225, 214, 112
    I think it's a personal preference. After a few decades, you will need to replace your rims because the calcium will eventually eat them. I think wheels look naked without weights on them, but that's just me. One thing for sure, you can get a tire off and on by yourself allot eaiser if they aren't loaded.
  5. #5
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    GreenRules
    Weighted tires on and off easier IF you remove the weights first?? [img]/forums/images/graemlins/wink.gif[/img]
  6. #6
    Elite Member rockyridgefarm's Avatar
    Join Date
    Mar 2002
    Posts
    4,454
    Road 4310
    Deere 4310 HST MFWD
    I loaded mine myself with used antifreez, it costed $6 total... That was for the fill adapter, I already had a submersible pump and a garden hose.
  7. #7
    Join Date
    Apr 2002
    Posts
    1,446
    Casco, Maine
    Yeah. That's what I meant. Sorry.
  8. #8
    Elite Member Cliff_Johns's Avatar
    Join Date
    Jan 2004
    Posts
    2,673
    Northern Illinois
    JD 4110
    Other reasons for maybe using wheel weights:
    Should you temporairly need a lighter tractor for some reason (mowing when it is wet, transport, driving over a bridge you're worried about) you can remove wheel weights. You can also remove the "downhill" wheel weights if need be for optimal stability on a slope. Not big plusses, but something to think about.
    Cliff
  9. #9
    Join Date
    Oct 2004
    Posts
    115
    Western NY
    John Deere 4410
    Well guys, I went thru the winter with double wheel weights with no problems but then I had the 430 FEL on the front and a 5' snow blower on the rear and I was on the driveway all the time. But now, with the blower off and the box scaper on the rear, I picked up a stump with a lot of dirt clinging to it and lifted the rear end off the ground. I did'nt like that. I really didn't want the extra weight for grass cutting purposes but now I think I should have tubes and Rim Gaurd put in the rear tires which will add about 1000 lbs. The 430 loader can lift more than this 4410 can handle safely without more weight on the rear end and according to JD's loader specs, the rear tires really nead to be loaded. Better safe than dead. I guess I can live with a few marks in the grass.
  10. #10
    Join Date
    Feb 2005
    Posts
    941
    Central WI
    I have loaded tires with Rim Guard, and personally prefer this. Loaded tires put the weight more directly to the tread surface rather than the rim to sidewall. This allows running a lower air pressure. You also have less rotating mass as while the fluid does take power to move, it does not spin with the tire.
    40 gallons per tire in my 43-16-20's for 828#. IIRC, it was $200 to do this. Not sure what cast weights are per #
    Rim guard is environmentally safe also.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
