Keoke
Gold Member
JD 4120 hydraulic add on\'s
Hi guys, I am in the process of setting up a 4120 on the JD web site and am confused on their choice of hyd options.
Can anyone explain what the following options are used for.
1. LVB25511 Electric diverter kit.$1,191
Is this for working the top and tilt three point rams from the loader joy stick when not using the loader? In short, does this solenoid valve switch fluid output between loader and top and tilt? Are the top and tilt rams plumbed or quick coupled into this valve?
2. LVB25513 Third Selective Control valve kit:$211
Is this used as a conventional dual control valve for top and tilt? Where is it mounted on the 4120?
3. LVB25312 Top and tilt field:$828
Is the above third control valve included in this kit along with the hoses and rams?
4. On the JD four and one bucket, can you factory buy this with the jaw control manipulated from the joy stick with a solenoid hyd valve or would this requir yet another control valve? Where would they mount this control valve, if separate?
5. Is there a factory option for a pair of steel hyd lines running down the loader arm for use of a 4n1 bucket or whatever? Part # ????
thanks a million,
thanks a million,
