Ok guys, I've given some consideration to the weight concern several have mentioned, and I'm curious as to how much weight loaded tires, water, will add to the tractor. Now I have never tried a 790, so I have no idea how it will perform. However, I have used another cut out in a field. This one weighs in at 2,474 lbs. With tires loaded and equipped with
R4's, it pulled a 5,500 lb spreader all around a plowed field and even up a slight grade in one particular place. No kidding, I was the driver. It actually did as well, maybe better, than a 2wd F 2000 that weighs in at 3600 lbs dry weight. I have no idea how much the thing actually weighs as it has its tires loaded also. Needless to say, I was very impressed with this cut. The only thing I didn't like about it were the
R4 tires. Its tires slipped some, but it kept going. My 2000 actually stopped and started spinning. I felt that with
R1 tires, this CUT would have truly been a wolf in sheep's clothing. By the way, this CUT was not carrying its
FEL at this time.
So I did the Math, We are looking at a 374 lb difference between these two CUTs. That just doesn't seem like that great of a difference. But I don't know, I haven't used the 790. Maybe an extra 200 or so lbs will make a world of difference.
So I pulled up John Deere to see what a little extra weight would cost. Wow $$$$!!!
I'm not sure how many plates can be added to each tire, but 100 lbs can be added to each rear tire for a little more than $200 per tire. The front bracket with around 168 lbs can be added for a little over $298. So to get this tractor's traction equal to one that I know, it will cost me nearly $700.
The 790's price might have just gone up. But then again, maybe not. [img]/forums/images/graemlins/confused.gif[/img]
