picker77
- Joined
- Feb 4, 2006
- Messages
- 385
- Location
- Central Oklahoma
- Tractor
- JD 3032E, dual remotes, TnT, tooth bar, grapple
Power Beyond vs. Dual remotes vs Top \'n Tilt, etc?
I'm a babe in the woods on modern hydraulics, my current old '79 model tractor only has the basics (3-pt and steering). Starting to think about a new JD 2520/200cx or 3120/300cx, but JD's "options" list in the hydraulics area is confusing me.
I want to be able to control two individual rear hydraulic functions in the future (tilt/angle on a blade, etc.). I'd also like to be able to hang a small 4-pt mount backhoe on in the future without having to have a bunch of rear hydraulic refitting done. So I'm assuming I need "dual remotes". However, do I also (or instead of)need "power beyond"? And what about "top 'n tilt" at $900? Does TNT make some of the other remote options unneccessary?
There are several JD hydraulic options I'm not sure I understand. For instance: the 3120 has "dual mid selective control valve" as standard, with an option for a "third selective control valve kit" for $211. Exactly what is "dual mid", and does putting the "third SCV kit" on do for you? Does that mean you end up with THREE rear remotes, or only a single plus the "dual mid SCV" setup (which I don't even know what is, let alone whether I need it).
I will never use a mid mount mower. I MIGHT use a snow blower someday, but not now. I just want a solid tractor with loader that can handle at least two plug-in rear hydraulic circuits. A third might be nice, but not sure what I'd need it for, and the power beyond vs dual rear remote thing has me temporarily befuddled.
I'm worried about all this now because I'm assuming that ordering the tractor new with all this stuff preinstalled is significantly cheaper than piecing it together with individual kits later. I hope that's correct.
Sorry for the ignorance, but we all gotta learn sometime...
