Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2005
    Posts
    584
    Sedro Woolley, WA
    Kubota L3400 (gear driven)
    Default John Deere mower tire pressure
    I just got four new tires for my LX178. The manual says 10 psi for the fronts and 8 psi for the rears. Seems kind of low to me. The tires are rated at 30 psi fronts and 22 psi rears (as stamped on the tires). The tire shop that mounted them had them inflated to 20 psi (front and rear).
    What's the best? Stick the JD manual? I just don't want to blow a bead off a rim at the lower pressures. Plus I weight about 230 lbs.
    Attached Images Attached Images
  2. #2
    Veteran Member ccsial's Avatar
    Join Date
    Jun 2005
    Posts
    1,631
    NorthWest Illinois
    (Kuboto L3400) (Ford 1910 4WD w/FEL) (Deere X748SE) All bought new
    Default Re: John Deere mower tire pressure
    I wouldn't hesitate to run them higher. The rear turf tires on my X748 are rated at 10 psi max as stamped on the tire. I have put tubes in the rears due to blowing air out the beads.
    Kubota L3400-HST, Ford 1900-Gear FEL, John Deere X748SE
  3. #3
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Stick to the manual's recommendation Shimon as the lawn tractor's don't need car like pressures to operate properly.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  4. #4
    Join Date
    Jun 2005
    Posts
    1,631
    NorthWest Illinois
    Quote Originally Posted by mjncad
    This is OK as long as you don't have trouble going flat due to the beads leaking. If you have trouble like I did you can try higher pressures or go to tubes. I used tubes because my tires are only rated at 10PSI. Had they been rated higher I would have use the highest rating on the tire.
  5. #5
    Platinum Member bontai_Joe's Avatar
    Join Date
    Feb 2004
    Posts
    834
    northeast PA
    Deere 316 (Kohler) Deere 316 (Onan) Deere 210
    The manual's recommendation will give you the softest ride. The tires are the only "suspension" you have on a tractor (no springs or shocks). But I generally run 20 in the fronts and 15 in the rears.
    If it's free, it's for me!!!!!
  6. #6
    Join Date
    Aug 2006
    Posts
    5,114
    A couple
    Quote Originally Posted by ccsial
    The only flats I had were from goatheads, and a bottle of Slime cured that problem.
  7. #7
    Join Date
    Sep 2002
    Posts
    130
    GA/ western NC
    Kubota L3010DT
    I agree with bontai_joe. I have an LX178 and run it with the specified air pressure. I added air in the past when I didn't have an air guage handy and noticed immediately the ride was harsh and traction on the steep ground noticeably less. I lowered it to specs and both ride and traction improved. I used to have trouble with the front tires going flat and added "slime" to all of the tires and haven't had a flat since.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
