425 coolant leak - help
   / 425 coolant leak - help #1
labsrus
Our 425 with 521 hours on it started leaking coolant and I am wondering how hard it is to replace the main gasket? I replaced the 2 smaller ones thinking it was them but it is the big main gasket. Can anyone give me an idea how hard it is to replace or if I should also check anything else if I take it apart?
Thans for any help.
   / 425 coolant leak - help #2
Here is a schematic and removal hints of a head. Which gasket did you replace?
   / 425 coolant leak - help #3
And the Cylinder head instal procedure.
beenthere - I replaced the 2 smaller ones on the front ( not the cylinder ones). The one leaking is the 3rd gasket ( biggest) on the front. It is right behind the 2 I took off. The part has the oil dipstick on it.
   / 425 coolant leak - help #5
Well, I'll take another shot at it. :)
This one includes the crankcase cover. Are you seeing the water leak from under this cover? I erred thinking you were talking head gasket. :eek:
I assume you have tried snugging each of these bolts up a bit, in hopes one or more might be loose?
This show what you need? Sequence of bolts is apparently important.
Yes, it is the crankcase cover gasket that is leaking. I did try to tighten the bolts up but it just made the leak drip more. It is leaking right above the #6 bolt at the gasket.
Is there anything I should know about it leaking at this gasket?
I would think it is not too hard to change the gasket? Is there anything I should look for if I do change the gasket?
Thanks for the picture.
Doug
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
