Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jul 2009
    Posts
    17
    GA
    Kubota M6800 4x4, ZD326, JD140
    Default 318 electrical issue?
    I had to take the Onan engine apart for a $1.89 cam thrust washer. Replaced cam bearings while in there. Now, after putting it back on the tractor more issues. To begin with I decided to fire it before I put all the covers and hood and stuff back on. With the engine bolted down, I sprayed a shot of ether in the carb and hit the switch. She fired right up for about 2 second
    After bolting on other stuff and hooking up gas line a few days later, I don't have a spark at the plugs. I have power at the points, the center lug going to the regulator and the positive side of the coil.
    Now, yesterday it wouldn't even turn over. I still have power in the same places. I even tried jumping the solenoid, nothing. It will turn by wrench on the crank like it should. I do notice a single blade black wire coming from the hour meter that is not hooked. The other black wire is hooked to the meter and it works when the switch is on. It's almost like 2 different problems. Electrical is my weakness on these things.
    Any ideas? How can I check the ignition switch, coil and condensor? I put an ohm meter on the coil with it unhooked. The needle jumps when place on the + and - sides of the coil and when placed in each plug hole at the same time. I don't get anything when checked from the + or - to either plug hole. I never checked a 2 plug coil before.
    Thanks for any help! Nathan
    Raising kids is sorta like putting socks on a chicken...
  2. #2
    New Member
    Join Date
    Sep 2010
    Posts
    8
    John Deere 455, 318, 420
    Default Re: 318 electrical issue?
    I would make sure ALL your grounds are good.
    Do a quick ohm check between the engine block and the negative battery post.
  3. #3
    Super Star Member
    Join Date
    Dec 2003
    Posts
    11,865
    NC
    Kubota Grand L3830
    I would start by looking at the fuses. I was helping a neighbor re-install the engine on an old Wheel Horse, some how we blew a fuse. Spent several hours head scratching before we finally got around to checking the fuses.
  4. #4
    New Member
    Join Date
    Jul 2009
    Posts
    17
    GA
    OK, I worked on it a little more over the weekend. I don't have internet at home. As it sits now, I can connect the 3 purple wires and touch them to the red/green and red/pink wires and it will fire up. But when connected to the switch I get nothing. I suspected a bad switch. I took a switch off another 318 parts tractor and get the same results. I guess both could be bad???
    I wonder if something in the safety circuit could be causing this? Both the switches have continuity between the lugs for the red/pink and red/green wires when switched on. And they have continuity between the 2 lugs for the purple/purblk and purple wires when turned to start.
    Because I can get it to run momentarily when jumping the switch, I don't think a fuse or ground is the problem.
    Any more ideas?
Similar Threads
  1. Briggs V-Twin electrical problem
    By Chuck52 in forum General Lawn & Garden
    Last Post: 08-31-2010, 09:30 AM
  2. Deere 318 starter issue
    By cef2lion in forum John Deere Lawn & Garden
    Last Post: 11-03-2009, 09:59 AM
  3. 1610 head gasket issue
    By Box in forum Yanmar
    Last Post: 08-20-2007, 01:00 PM
  4. 1610 head gasket issue
    Last Post: 07-09-2007, 06:39 PM
  5. JD 216 Rider Electrical Issue (Battery Not chargin
    By Derby6 in forum John Deere Owning/Operating
    Last Post: 06-20-2005, 11:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
