MilesToEmpty
Boy did I hit a winner on this.
Just got our 86 Deere 420 (newer Onan) lawn tractor running and I go and hit a solid 4x4x8" piece of pressure treated lumber.
I clipped it on the left side of the mower deck, and it jammed the deck instantly. The mower coughed and sputtered and as I was trying to recover, it died before I could disengage the PTO.
I drove it back to the garage and was able to pop the wood out with ease. Blade turned freely, no damage visible anywhere. Turn the blades and the 3 pulleys on the front of the engine would turn. If you grab the belt you can turn the pulleys and the blades with ease. So i know nothing is jammed or bent.
When you flick the PTO on now, it sounds almost like a steam engine chugging off, and the mower is very slow to, I guess you can say, fully engage.
Forget turning it on at anything other then idle... Just makes the puffing noises and it either does nothing (light always comes on) or starts spinning about 2x as fast as the second hand on a clock. It may or may not start up.
Before we would get a hiss and the thing would just engage, and run like a bat out of ****.
My question is, what happened when the crank was trying to power that PTO.
I have brand new belts and an idler pulley (not the issue since nothing up front really spins)
And the next thing... all the parts Im finding for this thing only show one belt up front. Ours uses 2. Am I just looking at the wrong information?
Thanks!
Thanks!
