Results 1 to 4 of 4
  1. #1
    Gold Member
    Join Date
    Jul 2003
    Posts
    331
    Central PA
    JD 4410, JD455
    Default 4X5 PTO solenoid replacement
    I replaced the PTO solenoid on my 455 trying to correct a no enagage PTO issue. Didn't fix it but had a question about the install. I had to remove the seat pan and lift the fuel tank to be able to get a wrench on the solenoid stem.
    When I installed the new stem the gasket marked 8 never touched the tranny case and the armature became tight. I could still move the gasket around. I removed and installed the old armature. Same issue. I pulled out the solenoid valve guts and tried again same results. Verify assembly via diagram. I ended up using two numer 8 gaskets. Not sure what isn't right here.
    Attached Thumbnails Attached Thumbnails 4X5 PTO solenoid replacement-ptosolenoid.gif
  2. #2
    New Member Greene400's Avatar
    Join Date
    Jun 2011
    Posts
    3
    Bedford, IN
    1982 John Deere 400
    Default Re: 4X5 PTO solenoid replacement
    Sounds like you are in the weeds there friend. I haven't messed with that, nor do I have that model of tractor.
    2 gaskets, sure doesn't sound right? I hope you get it figured out
  3. #3
    Veteran Member Gittyup's Avatar
    Join Date
    Oct 2007
    Posts
    2,411
    Mid Atlantic
    Kioti CK25 Shuttle Shift, loaded tires
    Wish I could help, but don't know. I will say the service manual leaves a lot unsaid. I just changed out the plastic cam gear in my 425, and the manual had limited usefulness. I'd never done anything like that to an engine. It wasn't too bad though, other than a stuck bolt where the motor mount attaches to the crank case cover. I had to buy a special socket to get it loose. Replaced the cam gear, push rods, tappets, water pump, governor gear, and oil pump gear, plus all seals. Bought valve springs and seals, but haven't done that yet. As long as it's not burning oil, I'm going to wait.
    Good luck. Not sure what is wrong, but doubt that 2 gaskets is the answer. Hope it holds up.
  4. #4
    Gold Member
    Join Date
    Jul 2003
    Posts
    331
    Central PA
    JD 4410, JD455
    I printed out the solenoid removal and installation pages from the service manual. Going to take it back apart and put back together per those instructions and see if it all goes back together using just one #8 washer as it should be. Service manual says to torque the armature but you need the JDDG757A special socket.
Similar Threads
  1. Ford 1700 & 1710 tractor parts
    By North Dakota in forum New Holland Owning/Operating
    Last Post: 02-08-2013, 06:32 PM
  2. Starter Solenoid replacement question
    By Richard in forum Parts/Repairs
    Last Post: 01-31-2011, 02:50 PM
  3. 1910 solenoid replacement
    By avclay in forum New Holland Owning/Operating
    Last Post: 07-12-2010, 03:13 PM
  4. PTO Solenoid Valve Repair
    By SpringHollow in forum Power Trac
    Last Post: 09-28-2009, 10:08 AM
  5. 4610 PTO stopped working
    By tallyho8 in forum New Holland Owning/Operating
    Last Post: 09-26-2008, 08:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
