I have a 1983 John Deere 318 that I recently bought with a bad starter. I have replaced the starter and the tractor seems to run well. The problem I have is that there is a leak in the rear end. When I shut the tractor off, a puddle of oil will form under it. The leak is coming from a spot on the right side of the tractor between the center section of the rearend and the housing that bolts to it that has the axle running through it. I bought a service manual for the tractor and it looks like there is a gasket at this joint. The service manual also talks about there being an engineering change made on later models to the way the rear end is mounted. On earlier models like mine, the way the rear end was mounted put stress on the rear end that could cause it to leak. Apparently this has happened to mine. How easy is the the gasket at this joint to replace and has anyone run into this before?
