Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Sep 2011
    Posts
    10
    john deere 455
    Default John Deere 455 steering cylinder leaking
    My steering cylinder is leaking like crazy...its between $275-299 for a new one ( non-serviceable, welded together) I am looking for seals for it but have not had any luck yet. I cut it apart at work, and would like to try and put seals in it and weld it back together......Any ideas where I can find seals for it? The JD part # is AM118796.......Thanks!!!
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,758
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: John Deere 455 steering cylinder leaking
    Andrew....that is the steering cylinder part # or is it the seal part # ? If seal, can it be ordered from Deere?
    The item is probably farmed out by Deere and the seal may be hard to find. I'd try to go to a bearing store and see if they can match it. Am assuming it isn't just an o-ring.
  3. #3
    New Member
    Join Date
    Sep 2011
    Posts
    10
    john deere 455
    that is the # of the cylinder....there is a buffer seal and then a lip/wiper seal on the outside......
  4. #4
    New Member
    Join Date
    Sep 2011
    Posts
    11
    1966 John Deere 110 rf
    Default
    Yes take the seals to a bearing house and they can match them up for you. I've rebuilt hundreds of cylinders and rarely buy from the manufacturer. Be careful takeing the old seals out, most have a small part number on the edge of the seal. If your good with a caliper measure them yourself and order online.
  5. #5
    Super Star Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    10,412
    Giddings, Texas
    JD 4310,JD5420
    What's the trick for welding one back together? How do you keep it from getting too hot? Do you just put it back together and push all the rubber to the opposite end?
    Pictures would be nice. I wish you success!
    One of these days....One of these days...
  6. #6
    New Member
    Join Date
    Jul 2013
    Posts
    1
    Mesquite, tx
    John deere 1997 455
    What is the best replacement for the power steering cylinder! My Dad has a 1997 455 ans it just started to leak! Other that paying $300 for a new part!
    Thanks Scott
  7. #7
    Gold Member
    Join Date
    Jun 2013
    Posts
    287
    N. GA
    LX188/445/755
    Order a new one from GFP and find the 5% off coupon code...
    Also get some new o-rings for the hose connections.
    And unless the pump is ALREADY leaking inside the column do NOT twist or disturb the hoses.
    I do NOT like how they designed these hose connections. (It's a real pita to get to the pump fittings.)
    My new cylinder did come with new ball joints.
    See the pin sticking out the side into the axle?
    John Deere 455 steering cylinder leaking-pin_800_8-12-2012-004-jpg
    Be sure to measure this to confirm 8mm or whatever the diameter is when selecting.
  8. #8
    Gold Member
    Join Date
    Apr 2011
    Posts
    415
    Kubota BX 2370
    Quote Originally Posted by BBO View Post
    What does the 8MM distance do ?
  9. #9
    Super Member
    Join Date
    Apr 2004
    Posts
    6,567
    East Coast of Lake Huron
    Deere, several
    For a measly $300 vs all time spent cutting, looking for parts, Rebuilding , welding together putting the tractor together and hoping the PS doesn't leak?
  10. #10
    Gold Member
    Join Date
    Jun 2013
    Posts
    287
    N. GA
    LX188/445/755
    Quote Originally Posted by Guido455 View Post
    It's the diameter of that pin. Did you click to enlarge the photo?
    It's a pin that is maybe 2" long and sticks thru a hole in the axle.
    All I see is that it keeps the cylinder from rotating.
Similar Threads
  1. John Deere 2305 Compact Tractor Transmission and rear PTO failure
    By JBarnes6767 in forum John Deere Owning/Operating
    Last Post: 04-18-2017, 01:44 AM
  2. John Deere Noise Canceling Headphones
    By Fug1000 in forum Kubota Owning/Operating
    Last Post: 11-08-2010, 10:57 PM
  3. John Deere 1070 Compact Power Steering Question
    By Brenttnhmby in forum John Deere Owning/Operating
    Last Post: 12-07-2009, 01:51 PM
  4. deere 4100 steering cylinder leaking
    By MARKMONKEY1 in forum Hydraulics
    Last Post: 05-07-2009, 12:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
