Results 1 to 5 of 5
  1. #1
    Elite Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    4,829
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar, & FS190
    Default How to mod LX266 to pull a 4' York Rake
    Guys,
    I have a good running LX266 16 HP mower (less than 200 hours).
    I believe the "hitch" for pulling a little cart is merely sheet metal bent 90 degrees with a hole in it.
    I have the possibility of buying a 4' York Rake from a friend who got ot for a Craftsman 18 HP mower with a better "hitch". The York rake is a nice one with the wheels and the drop down blade.
    I can and will add pictures after daylight.
    My questions are as follows.
    I want to use this York rake to rake leaves, and to lightly groom my gravel road to maintain its crown on the hill.
    I might use it to rake/scatter horse apples for better fertilization of the pastures.
    #1 - Will my 16HP LX266 haul it like this?
    #2 - How do I prevent this from ripping my little sheet metal "hitch" thingie off my mower?
    #3 - Is there a better "hitch" a noob like me without a welder can fab?
    I am sure I will have more questions later as you all edumacate me!
    Thanks in advance!
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, & more to come. Mowers 2003 JD LX266 42" deck mower, & old JD STX-38 (12.5 hp).
    Managing 51 Acres of Virginia hills with ponds & streams, mature market timber, riding trails, horse pasture, long gravel drive, veggie garden, & yard.
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: How to mod LX266 to pull a 4' York Rake
    David
    I think the hitch you have will take anything the LX266 can dish out. You likely will find that traction will be your biggest frustration when any kind of load builds up in the rake. I could be wrong, but I'd also bet on it.
    I suspect "sheet metal" is more likely around 3/16" steel plate formed to make the hitch.
    You may get more traction by adding wheel weights, but then you will be stretching the upper limits of power of the 16HP LX266.
    But do look forward to the pics. And some possibly pulling the 4' rake.
  3. #3
    Join Date
    Aug 2011
    Posts
    4,829
    Ladysmith, VA
    Quote Originally Posted by beenthere View Post
    David
    beenthere,
    Yes, the LX266 has a 3/16" steel plate single hole "hitch".
    Here are a couple pics of the 4' York Rake.
    My concern is the double hole nature of the York Rake will cause the pin to twist in the single hole of the LX266.
    Any ideas?
    David
    Attached Thumbnails Attached Thumbnails How to mod LX266 to pull a 4' York Rake-img-20111013-00088.jpg   How to mod LX266 to pull a 4' York Rake-img-20111013-00089.jpg
  4. #4
    Join Date
    Dec 2009
    Posts
    1,614
    S. W. Virginia
    Kubota B3200, Ford NAA, Deere 5203
    Find the proper length/dia. hitch pin, drop it in and go. I have a 265 JD that has been used for pulling a cart most of it's life (20yrs) and the hitch is showing some wear but still very useable. I'd say you're over thinking this.
    Kubota B3200
    Ford NAA Jubilee
    Deere 5203
  5. #5
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    As long as the clevis end of the rake allows room to drop a pin in through the hitch hole, you should be good to go. A quarter inch or 3/8 inch pin should give plenty of rotation allowance to not cause any problem. I don't see it as a weak point.
Similar Threads
  1. 8' York rake shop dolly
    By nickel plate in forum Projects
    Last Post: 03-08-2010, 11:41 AM
  2. Rake Intro to York Rake Attachment
    By Mcourchesne in forum Attachments
    Last Post: 05-28-2009, 10:21 PM
  3. I bent my York Rake!
    By MikeB64 in forum Parts/Repairs
    Last Post: 05-23-2009, 01:44 PM
  4. Rake Proper use of a "York rake"
    By Cletrac in forum Attachments
    Last Post: 07-25-2005, 06:12 PM
  5. Rake York Rake Owners:
    By DAP in forum Attachments
    Last Post: 04-21-2004, 12:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
