OP
rdschomm54
Member
Hello,
Well I guess I spoke too soon. I have the same condition AGAIN!!! After I installed the new Ignition Module the Tractor started right up and ran normal. I mowed about 3 1/2 acres and it quit. I have the same condition. Turn the key on everything lights up on the dash as normal and when you turn the key to start a relay clicks but does not engage the starter. I replaced the battery the first time and all the switches checked to be good. The starter solenoid was good before. I guess I'll go through the complete system again but this time I need to find out what is causing the Ignition modules to burn up. If in fact that is the problem again. I'll let you know once the checks are done.
Any body got any ideas???
Thanks!
Bob
Thanks!
Bob
