Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    May 2009
    Posts
    3
    Default 214 PTO Will Not Disengage
    Greetings: Today I took the JD 214 out of the shed, took off the plow-blade and installed the tiller attachment. All seemed ok, I did some tilling, but the pto will not disengage. The tiller keeps running even though I have moved the handle to the off position. Any and all advice gratefully accepted.
    Thanks in advance.
    Eugene Coldrick
    Noel, Hants County
    Nova Scotia
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: 214 PTO Will Not Disengage
    That is a mechanical linkage, right?
    What is the s/n of the 214?
  3. #3
    New Member
    Join Date
    May 2009
    Posts
    3
    It is a mechanical linkage, sir. The S/N of the machine is: C214E055384M.
    Today, it is freed up, again. I'm not sure if it was just some dirt jammed in there, or what. I am not sure where the adjustment would be for the brake shoe.
    Thanks guys.
    Eugene.
  4. #4
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    On the tiller, where does the drive belt go?
    Across an idler pulley that is used to engage the tiller, or does the tiller get driven off the PTO clutch that also is used to drive the mower deck?
  5. #5
    New Member
    Join Date
    May 2009
    Posts
    3
    Default
    The tiller runs off the main pto pulley. There is an intermediary pulley to route a round belt to the tiller. I can post a pic, tomorrow, if you like. It's a cute little rig. So I guess you're right about there being an idler pulley.
  6. #6
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    That helps.
    There is an adjustment on the engage/disengage arm on the clutch. It may just be sticking when you disengage, thus the pulley doesnt release and keeps running.
    Watch it closely and see if that arm needs to be adjusted to do it's intended task.
    I used to have a 212, and recall having to keep that adjustment just right for the clutch to work properly. On mine, the clutch had a brake pad on a small adjustable strap that would contact a free running clutch sheave and bring it to a stop. That required a fine adjustment and tuning to work correctly too. I didn't have the tiller, only the mower deck. Liked it a lot, but it did take some care and attention to stay "tuned", as does the variable speed drive.
  7. #7
    New Member
    Join Date
    Feb 2011
    Posts
    12
    John Deere/Allis Chalmers/New Holland
    If I recall, there are springs on the left side of the pulleys. Are they there or missing. I believe that there are two of them.
  8. #8
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    rk
    I believe you are right, and here is a pic of the parts (for the later s/n 's )
    Attached Thumbnails Attached Thumbnails 214 PTO Will Not Disengage-214_pto_parts.jpg
  9. #9
    New Member
    Join Date
    May 2012
    Posts
    3
    Goshen, Ohio
    Cool Re: 214 PTO Will Not Disengage
    Thanks guys. Glad I'm not the only one with this concern.
    Mine has been acting up for years and just got me in trouble yesterday.
    I can't force the PTO to come free even with a crowbar until it cools off, usually overnight.
    After I cleaned the friction material up last time it worked well for a couple mowings. (no signs of overheating damage or discoloration).
    Is there a permanent fix? Like replacing the piece with the lining on it?
    I just don't see how an adjustment can keep it from wedging together???
    Thanks,
    Lloyd
  10. #10
    New Member
    Join Date
    May 2012
    Posts
    3
    Goshen, Ohio
    The lining was covered with grease again. The seal is discontinued and no one seems to have any left. So I just cleaned nearly all the grease from the bearing and put it back together again. BTW, this deck is the nicest cutting deck I have ever used...
Similar Threads
  1. L2800 PTO Issues
    By Hanksride in forum Kubota Owning/Operating
    Last Post: 03-25-2012, 09:46 AM
  2. Mower PTO will not disengage
    By daydremer152 in forum Craftsman / Sears
    Last Post: 05-21-2011, 08:26 PM
  3. LT1050 PTO disengage issue
    By trandolph in forum Cub Cadet L&G
    Last Post: 04-24-2010, 05:14 PM
  4. 4300 PTO won't disengage.
    By billt102 in forum John Deere Owning/Operating
    Last Post: 04-19-2010, 07:49 PM
  5. L2800 PTO won't disengage!
    By pax_tractor in forum Kubota Owning/Operating
    Last Post: 04-08-2007, 06:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
