Results 1 to 10 of 16
04-16-2012, 02:02 PM #1New Member
- Join Date
- Apr 2012
- Posts
- 7
- Location
- rome city, Indiana
- Tractor
- john deere 316
316 no hydrolics
i recently replaced the engine and the mower sat for two years. it sat with the lever that allows for manual push, that releases the pressure, down from when i pushed it in the shed. now i took out the release vavles and checked them and they seemed fully functional. i turned the engine on and pressed the release vavles with the engine running and i noticed the one left of center depressed slow than the right of center. so any help? ask any ?'s if you have any
04-16-2012, 03:35 PM #2Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
Re: 316 no hydrolics
So is the problem/question that there is a difference in the speed of the two valves?
Or after checking them for 'function', the 316 will not move forward or back when moving the control to forward/reverse?
Any other history of things happening that might be related? Transmission fluid change, filter change?
Hope we can get some good answers for you.
04-16-2012, 03:42 PM #3New Member
- Join Date
- Apr 2012
- Posts
- 7
- Location
- Tractor
- john deere 316
i put a 3 cylinder cat diesel engine in the lawn tractor, i reomoved the wiring harness and the computer, i don't think it would but is there anything stop it from working?
04-16-2012, 03:45 PM #4New Member
- Join Date
- Apr 2012
- Posts
- 7
- Location
- Tractor
- john deere 316
it will not move forward or backwards and the deck won't go up and down
04-16-2012, 05:15 PM #5Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
Ok.
Sounds like you are going to have to get some pressure checks to see if the charge pump is producing pressure. And I don't know how to do that on the 316.
I haven't searched TBN for hydraulic info on the 316. It may turn up something helpful.
Anything ring a bell that may contribute to this when you exchanged engines? Same engine size, etc. ?
Any movement problems before the engine exchange?
Was this tractor operated by you before the engine exchange?
04-16-2012, 06:15 PM #6New Member
- Join Date
- Apr 2012
- Posts
- 7
- Location
- Tractor
- john deere 316
it worked well before the engine blew. absolutely no problems. the new engine is a 3 cylinder inline 1.1l. so i need to check the pressures from the pump?
04-16-2012, 06:40 PM #7
What way did you mount the new engine? A 316 as are most lawn tractors is driven from the blower end of the engine. If you mounted the new engine so that your driving the pump from the flywheel end you have the input rotation to the pump wrong.
04-16-2012, 06:53 PM #8New Member
- Join Date
- Apr 2012
- Posts
- 7
- Location
- Tractor
- john deere 316
your serious? the new engine rotates counter clockwise. when the engine blew i scrapped it soon after. then 2 years later which is now i put the engine in. so i figured 50/50 chance. any way i could change the pumps position to make it work?
04-16-2012, 08:32 PM #9
Hey Jake
Man what are the odds of that happening!the new engine rotates counter clockwise.
Anyway,I know with the Onan being that it rotates CW,if you happen to install the charge pump housing 180 degree out it won't pump. Being you're rotating CCW,and you put the housing out 180 (upside down)..well who knows. Wouldn't hurt to try.
Greg2009 2520
FEL/61" HD bucket/replaceable cutting edge
62D2 MMM
IMatch Quick Hitch
Homemade 3PT Receiver
Homemade Ballast Box
Woods GB65 Box Blade
A "REAL" snow blade --- JD 380A
90% Restored 1987 JD 316
MY BALLAST BOX:
http://www.tractorbynet.com/forums/b...box-build.html
MY SE SEAT 2520 MOD:
http://www.tractorbynet.com/forums/j...my-2520-a.html
04-16-2012, 09:11 PM #10Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
The plot thickens.
Let's hope for an easy fix.
Similar Threads
New GC2410 3pt. hitch hydrolics issue
By fozzy in forum Massey Ferguson Owning/OperatingReplies: 23Last Post: 06-08-2011, 12:46 PM -
89 316 issue
By farmerjim in forum John Deere Lawn & GardenReplies: 5Last Post: 10-11-2010, 06:44 AM -
update/ improve hydrolics, alternator?
By SI2305 in forum John Deere Owning/OperatingReplies: 3Last Post: 02-07-2010, 01:08 PM -
NH 315 vs 316 balers
By Brent.Roberts in forum Owning/OperatingReplies: 8Last Post: 07-20-2008, 01:32 PM -
3520 hydrolics for grapple/4 in one bucket
By prowley in forum John Deere Buying/PricingReplies: 9Last Post: 06-09-2008, 07:00 PM
