Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,772
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: John Deere 320...no fuel
    Need to figure out which 320 model this one is.
    Check out this site, to see if it is this model and with these serial number possibilities.
    TractorData.com John Deere 320 tractor information
    According to jdparts, some 320 models have fuel injection, and the pumps are different.
    Follow the fuel line from the tank to the engine to decipher if there is a fuel pump with a wire connector to it (fuel injected engine) or if it is attached to the engine (mechanical pump- no wire).
    Pulling the fuel line off at the carburetor and turning on the key should give a flow of fuel if it is the electric pump. Will have to crank on the engine to see if the mechanical pump will produce some fuel at the carb.
    Should be able to remove the screw bolt at the bottom of the carb bowl to drain the carb of fuel too.
    Here is carb showing parts. Also showing the mechanical fuel pump (# 9) on the front of the engine block, and also showing the fuel lines from the tank to the engine with the electric fuel pump (#37)
    Attached Thumbnails Attached Thumbnails John Deere 320...no fuel-320_carb-jpg   John Deere 320...no fuel-320_fuel_pump_mech-jpg   John Deere 320...no fuel-320_fuel_inject_lines-jpg
  2. #12
    New Member
    Join Date
    Apr 2012
    Posts
    4
    Montreal, Canada
    John Deere 320
    thanks for the advice...its a 320
Similar Threads
  1. Oil & Fuel DieselAdditive
    By Piperflyer in forum Owning/Operating
    Last Post: 06-23-2011, 12:35 PM
  2. Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
    By FRIZ in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2009, 05:03 PM
  3. John Deere Warranty
    By Big8 in forum John Deere Buying/Pricing
    Last Post: 04-18-2005, 08:00 AM
  4. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 05:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
