JDTank
- Joined
- Oct 5, 2010
- Messages
- 695
As someone else mentioned, I would keep in mind how often you plan to remove the deck.
For me, I remove my deck whenever I am not mowing, because I spend a lot of time hauling around the cart full of gravel, or pole shavings, or dirt. If I kept the deck on in some areas I would get hung up, so every time I want to do other work I just take it off. The additional bonus is it lightens the load the tractor has to carry by 250 or 300 pounds, whatever the deck weight is, which is heavy! I can use that for extra payload, or just make life easier for the tractor. With the 7-iron it takes 30 seconds, and not one second of that requires me bending over to push a deck out from underneath, or trying to line it up again when I want to put it back on. After having a 7-Iron I would never go back to a yellow deck.
