Results 1 to 4 of 4
  1. #1
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,763
    Northern, IL
    Branson 2400H, JD X540
    Default 425 valve clearance
    On a 425 with the Kawasaki 20 HP FD620 (I think, label is faded and scratched) engine what is the correct valve clearance spec? I have found three different specs. One said both at .004, one said both at .010 and one said intake .005-.007 exhaust .008-.010.
    I believe the last one of .005-.007 and .008-.010 is correct but would like to make sure.
    TIA
    Roy
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD X540
  2. #2
    Gold Member uglyboywith11fingers's Avatar
    Join Date
    Sep 2011
    Posts
    458
    Georgetown, Ontario
    2007 BX24TLB, 1998 TG1860G
    Default Re: 425 valve clearance
    I have the Kawasaki 18HP liquid cooled in my kubota TG1860G.
    The service manual says both intake & exhaust at .0098 cold.
    Pete
  3. #3
    Elite Member Gittyup's Avatar
    Join Date
    Oct 2007
    Posts
    3,142
    Mid Atlantic
    Kioti CK25 Shuttle Shift, loaded tires, JD X739
    My manual says 0.010
  4. #4
    Member
    Join Date
    Apr 2013
    Posts
    49
    NC
    1993 MF240 w/ 2400QT FEL
    Not trying to revive a dead thread but wanted to add this info and confirm Gittyup's post... I was looking for the same information for my 1997 Cushman Truckster which has the same engine.
    Valve Adjustment From Manual
    Valve Clearance When Cold
    Intake and Exhaust 0.25 mm (0.01 in)
Similar Threads
  1. Valve Clearance
    By thenorth in forum Chinese Tractors
    Last Post: 11-17-2011, 10:08 AM
  2. Valve Clearance procedure
    By mostly_gas in forum New Holland Owning/Operating
    Last Post: 05-07-2011, 10:44 AM
  3. Checking Valve Clearance?
    By Jeff244 in forum Parts/Repairs
    Last Post: 04-22-2008, 12:27 PM
  4. Valve Clearance Settings
    By wyvern in forum New Holland Owning/Operating
    Last Post: 04-13-2005, 08:16 PM
  5. checking valve clearance
    By geneP in forum Kubota Owning/Operating
    Last Post: 08-27-2000, 06:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
