Results 1 to 10 of 10
08-13-2012, 08:57 PM #1Gold Member
- Join Date
- Sep 2011
- Posts
- 271
- Location
- Upstate, NY
- Tractor
- 1949 Farmall H, Case 580CK Hoe
This doesn't look good (JD 748)?
After a muddy session I was getting ready to power wash our JD 748 and saw that the rubber housing in the attached pics had been torn.
It looks to be more than a minor job to fit a new one, but also is there another piece of some kind missing where the shaft is coupled with the front axle? Just doesn't look right as I'm seeing it now but as I've never paid that much attention before so not sure what I should be seeing.
08-13-2012, 10:25 PM #2Silver Member
- Join Date
- Dec 2002
- Posts
- 148
- Location
- South Mississippi
- Tractor
- B 2910 HSD, B2150 HST, Farmtrac 300DTC, Grasshopper 721D, JD 455
Re: This doesn't look good (JD 748)?
Unless it is just hidden from view it seems to be missing the drive shaft. Should be something connecting from the transmission. Have you looked up underneath?
tractorworks
08-14-2012, 08:31 AM #3Platinum Member
- Join Date
- Jun 2011
- Posts
- 595
- Location
- Connecticut
- Tractor
- JD2520
The parts catalog leads me to believe that the rubber boot is there to keep the U-bolt clean and free of debris. The pipe collar "floating" ahead of it in your picture seems to back that up.
Try sliding the boot forward as you may find a release collar to pull the drive shaft back and that boot would then come right off.
08-14-2012, 09:30 AM #4Gold Member
- Join Date
- Sep 2011
- Posts
- 271
- Location
- Upstate, NY
- Tractor
That's it exactly. I had the service guy at the dealer take a look this morning and he confirmed that the rubber boot wasn't necessarily mission critical, but rather useful for the purpose you describe. I just was concerned that there may be another part or collar of some kind missing. He said if I can't get it back on in some fashion that it would be ok to remove it untill I get a replacement. Apparently the shaft itself has to be disconnected to do that given the boot is a solid piece.
Thanks to all for the input!
08-14-2012, 09:45 AM #5Platinum Member
- Join Date
- Jun 2011
- Posts
- 595
- Location
- Connecticut
- Tractor
- JD2520
Although the dealer is "ok" with you operating without it, you will still likely want to be cautious. That part wasn't installed for absolutely no reason...
You might want to ask another dealer maybe even get some other 748 owners to chime in on what it is truly for and under what circumstances you could run without it (think 'heat shield' on your exhaust... They are NOT critical for vehicles that are never parked or operated on anything other than pavement / asphalt).
Also - I earlier said U-bolt, meant U-joint. It seems that you knew what I meant, though, so hopefully all good there.
08-14-2012, 09:54 AM #6Gold Member
- Join Date
- Sep 2011
- Posts
- 271
- Location
- Upstate, NY
- Tractor
08-14-2012, 11:13 AM #7Platinum Member
- Join Date
- Jun 2011
- Posts
- 595
- Location
- Connecticut
- Tractor
- JD2520
08-14-2012, 12:20 PM #8Veteran Member
- Join Date
- Jan 2010
- Posts
- 1,929
- Location
- Northern, IL
- Tractor
- Branson 2400H
the protective boot is to to keep grass, weeds, fingers, etc. out of the u-joints. Is it critical for operation, no, but if you run in long grass it may wind around the drive shaft and become a real tangled messthat could lead to damage of some other components.
RoyArtificial Intelligence will never overcome natural stupidity.
Branson 2400H MMM & FEL
JD 112
BX1850 gone but not forgotten
08-14-2012, 01:38 PM #9
I had a similar type boot fail on a 30 year old Ford 1100 I recently bought. I didn't want to try to disconnect a drive shaft for the 4wd so I bought a $3 rubber drain pipe connector, split it to slip over the shaft, trimmed it to the correct diameter, and glued the split with some good rubber glue after I had it over the shaft. Is held in place with hose clamps as the original was. Worked great, was fast and easy, and cost about $10 total. I'll try to attach a photo of the finished installation. I put a piece of duct tape over my glued seam for added protection.
Attachment 276882
08-15-2012, 11:56 AM #10
it doesn't look like a horrible fix actually,
see if you can look back where the shaft comes
out of the transaxle, you should have a bolt you can
remove, and take the whole shaft off, replace the boot,
and reinstall fairly quickly.
see if this helps:
1. Remove nuts (C) and bolts.
2. Slide the drive shaft (A) toward the front of the machine, removing the rear drive shaft yoke from the differential drive shaft (B).
3. Slide drive shaft toward rear of machine to remove shaft from the differential input shaft.
4. Inspect all parts for wear or damage. Replace any unserviceable parts.
Note: The U-joint yokes are not serviced separately. If either yoke is damaged, replace the drive shaft.JD X585 with 45 loader, 3ph, 62C deck, 47SB, 54 blade, Soft Cab. JD F525 with 48". JD 4X2 gator. JD T23 trimmer
JD CS56 and CS36 saws. JS35 WB mower.
Similar Threads
X740 and 748 changes over the years?
By KennedyDiesel in forum John Deere Lawn & GardenReplies: 12Last Post: 07-12-2012, 10:21 AM -
Thank God for good tunes, good friends, and Bud Light!
By Jstpssng in forum Related TopicsReplies: 8Last Post: 05-21-2010, 09:57 PM -
considering trading-in 3520 for 748
By hpc in forum John Deere Owning/OperatingReplies: 30Last Post: 02-22-2008, 05:01 PM -
Anyone have a John Deere 748?
By ccsial in forum John Deere Lawn & GardenReplies: 8Last Post: 09-17-2006, 12:43 PM -
Rear Finish Mower What features makes a good rear finish mower good?
By 8561 in forum AttachmentsReplies: 10Last Post: 06-28-2004, 11:53 AM
