Results 1 to 2 of 2
10-22-2012, 02:07 PM #1New Member
- Join Date
- Oct 2012
- Posts
- 1
- Location
- maumee oh
- Tractor
- 737
737 ZTrack Kawasaki 23HP
Blew the engine (FH680D-AS04) and deere wants $3000 for the engine alone with no install. Seems as if Deere has this engine on a restricted list which you can't find it other than through your Deere dealer. I found a similar engine (FH680D-S08) which appears to be the same only doesn't have the shaft and pulley coming out the flywheel side oif the engine. This engine is around $1,800. Wondering if I can purchase it and bolt my shaft / pulley on it and be okay? The pully is used to drive the belt for the hydraulics on each wheel. Thoughts / Comments? Thanks,
02-03-2013, 10:19 AM #2New Member
- Join Date
- Feb 2013
- Posts
- 1
- Location
- Oxford, PA
- Tractor
- John Deere 737
Re: 737 ZTrack Kawasaki 23HP
I have the same problem described above. I have a John deere 737 with a Kawasaki FH680D Engine that is blown. Has anyone replaced the engine with a new Kawasaki FH680D-S08 or FH680D-S01 engine? If so, can you tell me exactly what modifications you had to make?
Similar Threads
Kohler 23hp lifter noise
By turbojerk in forum Cub Cadet Yanmar & CUTsReplies: 69Last Post: 03-27-2012, 08:42 PM -
L130 23Hp OHV
By geno75044 in forum John Deere Owning/OperatingReplies: 10Last Post: 07-25-2011, 07:25 PM -
997 ZTrack Mower
By sunnyside360 in forum John Deere Lawn & GardenReplies: 2Last Post: 05-06-2011, 09:55 PM -
1980 Kubota 23HP
By papafarmer in forum Buying/Pricing/ComparisonsReplies: 5Last Post: 09-20-2004, 11:13 PM -
JD757 Ztrack
By smilingreen in forum John Deere Owning/OperatingReplies: 0Last Post: 08-30-2003, 11:31 PM
