Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Super Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar (For Sale), CS261, & FS190 + Echo CS400 & rusty old Ranger snowplow truck
    Default Re: LX266 Mower smells like gas?
    Well I moved the mower to the carport and NOW I have found a tiny wet spot underneath and there is clearly some sort of leak in the fuel line or similar. There is gas seepage on the undercarriage of the mower and it would be leaking ontop of the mower deck if it was still attached.
    I'm ging to have to take the seat, body, etc off and try to find where the fuel line is damaged...
    I am getting closer!
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, Titan 48" Pallet Forks, & more to come. & 2003 JD LX266 42" deck mower.
    Managing 51 Acres of Virginia hills with ponds & streams, Freshly replanted Loblolly!, riding trails, empty pasture, long gravel drive, garden, & yard.
  2. #12
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    With the help of a buddy (I needed at least 3 hands) I fixed the gas leak on Sunday.
    The problem was the fuel line had cracked under the body, near the seat. It had dried out and about a 12" section in the middle was cracked like a desert mud flat...
    So we replace the entire 5.5' of fuel line from the tank to the carb.
    We also replaced the drive belt while we had the mower apart anyway.
    Thanks for all the advice.
    This one got fixed finally.
    Be well,
    David
    Attached Thumbnails Attached Thumbnails LX266 Mower smells like gas?-2013-04-27-17-45-a   LX266 Mower smells like gas?-2013-04-27-17-45-a
Similar Threads
  1. New Problem on LX266 mower! Hydrostatic issue!
    By MossflowerWoods in forum John Deere Lawn & Garden
    Last Post: 06-14-2012, 02:03 PM
  2. LX266 mower making strange noises when PTO (Mower) engaged
    Last Post: 06-05-2012, 01:07 PM
  3. How to mod LX266 to pull a 4' York Rake
    Last Post: 10-13-2011, 10:12 PM
  4. Bagger for my JD LX266
    By mnsrx in forum John Deere Buying/Pricing
    Last Post: 06-19-2010, 07:32 PM
  5. Replies: 3
    Last Post: 07-09-2008, 03:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
