Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Platinum Member Carl Bert's Avatar
    Join Date
    Jul 2010
    Posts
    865
    Rockland county, New York
    Kubota B26, John deere X595
    Default
    Quote Originally Posted by avar
    That kit looks a lot like what I saw on the old tracktor where the snowthrower came from. Thank you very much.
    Carl that is a pretty nice setup with the cab, when the wind starts blowing the snow around that looks like it would be very comfortable, was that something that JD sold?
    Thank you again for all the replies,
    Not a John Deere, it's a 12 year old Curtis cab. You can't beat a cab when the wind is blowin!
    2010 Kubota B26 TLB w/hyd thumb. 2004 John Deere X595 w/62" MMM.
    Carl Bertuzzi
  2. #12
    Elite Member Dutch445's Avatar
    Join Date
    Aug 2001
    Posts
    2,638
    Upstate NY
    JD X585
    Default Re: GX335 54" deck and 42" snowthrower
    Quote Originally Posted by Carl Bert View Post
    couldn't agree more! my X585 with blower and cab is an awesome snow removal machine. someday i may add a heater, but
    i really don't need it, i'm not out there that long.
    JD X585 with 45 loader, 3ph, 62C deck, 47SB, 54 blade, Soft Cab. JD F620 with 60". JD HPX gator. JD T23 trimmer
    JD CS56 and CS36 saws. JS35 WB mower.
  3. #13
    New Member
    Join Date
    Dec 2012
    Posts
    8
    Mount Albert
    John Deere GX335
    Well, I got the remaining parts and put it together the best I can, the manual is going to take 4 -5 weeks so I couldn't wait. I haven't powered it up, it's too early in the morning but before I do I have to question if I put the rockshaft, lifter and yolks on correctly. The reason is that I had to loosen the yolks a fair bit before they would line up to connect to the rockshaft
  4. #14
    Gold Member fgross335_2210's Avatar
    Join Date
    Jul 2003
    Posts
    362
    West Michigan
    2210, 355D, 1950 Model B
    I don't remember having to loosen anything up to install my kit but I wouldn't be too concerned. Just make sure the parts are oriented like the diagram that was posted earlier in this thread.
    Fred G
    2210/FEL/62C, 355D/54C
  5. #15
    Join Date
    Aug 2001
    Posts
    2,638
    Upstate NY
    JD X585
    where did you get those yokes from? were they given to you from the original setup? or were they
    new parts you had to buy after the fact?
    if they were from the original setup, was the blower on the exact tractor model? or just a similar model
    like a 345 instead of a GX?
  6. #16
    New Member
    Join Date
    Dec 2012
    Posts
    8
    Mount Albert
    John Deere GX335
    the yokes were on the frame of the snowthrower that was used on the same model GX335 that I got the rockshaft and lifter from. It was an older model, by a few years by the look of it. I started it up thinking the hydraulics were not all the way down and it does seem to work, it's lifting about 4" off the ground. The thing that confused me was that I loosend the yokes and lifted the blower about 2 inches so that I can pin the yokes to the rockershaft. There is no play in the yokes when the blower is on the ground so I imagine it's pulling the tractor's front end down a little. From what I can see there is nothing else holding the snowthrower up other than the 2 yokes hooked to the rockershaft and the two hooks that hook on at the end. There is a the stablizer bar on the snowthrower that I can't see where it connects to, any idea where that might go?
    GX335 54" deck and 42" snowthrower-img_9275-jpg
    GX335 54" deck and 42" snowthrower-img_9276-jpg
    GX335 54" deck and 42" snowthrower-img_9277-jpg
    GX335 54" deck and 42" snowthrower-img_9274-jpg
  7. #17
    Join Date
    Jul 2003
    Posts
    362
    West Michigan
    The trackbar should attach to a hole in the front weight bar, the part of the frame that is exposed when the center plastic bumper is removed.
    Pretty sure the snowthrower on our 355 only raises 4-5 inches off the ground......
    Fred G
  8. #18
    New Member
    Join Date
    Dec 2012
    Posts
    8
    Mount Albert
    John Deere GX335
    Yes, I found the hole under the front bumber, I tried that initially but it didn't seem to fit till I lifted and lowered the blower, I imagine it was a little out of line. Looks like I'm almost ready for snow, I put the weights on the wheels and I have the chains left to do.
    Thank you again everone for your help, it make all the difference.
    Angelo
  9. #19
    Join Date
    Aug 2001
    Posts
    2,638
    Upstate NY
    JD X585
    snow? what's that?
  10. #20
    Join Date
    Jul 2010
    Posts
    865
    Quote Originally Posted by avar View Post
    The stabilizer bar that you mentioned attaches just like fgross said, when the front center plastic bumper is removed, you will see the hole where it connects. One other thing I wanted to mention. You need to have the mower deck height adjustment set at zero, to get full lift on the blower. If I remember right, once I did that the blower lifted 6 to 8 inches off the ground. I say 6 to 8 because the blower did not lift level. One side was higher then the other. The stabilizer bar has 2 or 3 holes in it. Playing around with that helped level it some, but not 100%.
    Carl Bertuzzi
Similar Threads
  1. 1960s sears ss12 mower deck master pully "replacement"
    By Tristen124 in forum Parts/Repairs
    Last Post: 09-11-2012, 08:27 AM
  2. 60" 7 iron vs 54" or 62" deck on 700 series
    By KennedyDiesel in forum John Deere Lawn & Garden
    Last Post: 07-13-2012, 06:13 PM
  3. Replies: 13
    Last Post: 05-31-2009, 08:50 AM
  4. Mower Deck: "Float" or "Hang"
    By ancientlake in forum General Lawn & Garden
    Last Post: 04-25-2008, 11:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
