jymbee
I have a JD 748 with snow plow. Given I have some areas of uneven, gravel ground the float setting for the plow works well. Helps prevent digging in on those uneven spots. However around the end of last snow season the float wasn't working. Push the level all the way in to activate the float, and the plow would just dip a bit but not work as it should.
I expect to try and deal with this when I install the plow this season and am wondering if there's some kind of adjustment or mechanism I should be looking at to get the float back?
