Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Platinum Member JDTank's Avatar
    Join Date
    Oct 2010
    Posts
    695
    Default JD 18 steel cart
    If anyone has one of these carts, could you please post pictures of how the tailgate works, and a picture of the body in the dumping position.
    I want to see exactly what these things do before I pull the plug on one, and there is little to no information available online.
    Thank you!
  2. #2
    Join Date
    Jul 2012
    Posts
    1,131
    Southeast Minnesota
    JD 4720, JD X748SE, JD 997, Farmall "B"
    Default Re: JD 18 steel cart
    Quote Originally Posted by JDTank View Post
    Thank you!
    I have one, But I might not be able to get any closeup pictures for a while. It's a nice wagon. I have a new tailgate ordered... My wife ran over it and smashed it all up. You can look on JD parts and at least see the drawings there.
  3. #3
    Join Date
    Oct 2010
    Posts
    695
    Quote Originally Posted by arlen4720 View Post
    If you can get photos I would appreciate that.
    Ran over the tailgate?! I won't even ask.
  4. #4
    Join Date
    Jul 2012
    Posts
    1,131
    Southeast Minnesota
    Hopefully these show you the basics.
    Attached Thumbnails Attached Thumbnails JD 18 steel cart-0219131622d-jpg   JD 18 steel cart-0219131622b-jpg   JD 18 steel cart-0219131622a-jpg   JD 18 steel cart-0219131624a-jpg   JD 18 steel cart-0219131623b-jpg
  5. #5
    Join Date
    Oct 2010
    Posts
    695
    Thanks, those are exactly what I needed!
    My #18 cart is on order at my dealership, should be here in a few weeks.
  6. #6
    Bronze Member glgeek's Avatar
    Join Date
    Mar 2012
    Posts
    63
    minnesota
    X728
    i have a #10 cart that is 22+ years old. pretty beat up and proud of it. has done a lot of work for me.
    you may be a little leery of this, but i cut off the front couple inches of the tongue and bolted on a ball hitch. having a ball on the tractor lets me pull around another utility trailer i have without switching back and forth. since you have the receiver on the new X740, you can get the correct drop on the draw bar to keep the cart level.
    do you needs pics of it?
    ba
  7. #7
    Join Date
    Oct 2010
    Posts
    695
    Quote Originally Posted by glgeek View Post
    ba
    Actually I am going to go with 2 different carts, but I just might take your idea and use it.
    I want the #18 cart because of the tailgate design. It will empty completely without having to shovel it out like the Poly carts. However, if your throwing in logs or big rocks, it will dent this thing up in no time. I ordered the #18 for loose light material, and a 17AT (all terrain) version of the 17 poly cart. I plan to use that for big rocks or throwing in heavy items. I opted for the All Terrain version over the normal 17P because it has a much higher ground clearance with the bigger tires, therefore the bed will go higher and it should empty itself out or close to it. It also has fenders, and high speed bearings in the wheels.
    The 17AT is a ball hitch setup, so I agree it would save me a lot of time if I convert the #18 to a ball setup too.
    If you have pictures I would appreciate some!
    2012 John Deere X740
    #18 Steel cart.
    Front fender kit.
    Brush guard.
    SE seat.
  8. #8
    Join Date
    Jul 2012
    Posts
    1,131
    Southeast Minnesota
    how much does an 18 cart cost? I got mine "thrown In" when I bought my X748 6 years ago. I throw rock and logs into mine all the time, life's too short to worry about denting the thing.
  9. #9
    Join Date
    Mar 2012
    Posts
    63
    minnesota
    X728
    as you can see, this is one tool i have not babied. it has hauled a lot of rock, dirt, logs and concrete. they don't stay new for very long.
    anyway, i cut off a couple inches on the front of the tongue and bolted on the hitch. i also painted the tongue and under-carriage yellow. the copper pipe spacers are to prevent the tongue from deforming while i tightened the through bolts. the body may be beat up, but the moving parts get frequent service and have never failed me. the tires are original.
    JD 18 steel cart-img_1465-jpgJD 18 steel cart-img_1466-jpgJD 18 steel cart-img_1467-jpgJD 18 steel cart-img_1468-jpgJD 18 steel cart-img_1469-jpg
    ba
  10. #10
    Join Date
    Oct 2010
    Posts
    695
    The #18 cart is about $400 here in Canada. I tried to get mine thrown into the deal with my X740, but I already rang the Salesman so dry on the tractor sale, he kept insisting there is "nothing left in it for him" He was kind of miserable before I left, I know what these machines go for up here, and I think I landed my X740 for close to dealer cost, so he didn't make much money! He didn't even know about the $1,000 rebate on the X700 series until I told him, once he tacked that additional savings on, you could almost see him cry!
    Thanks for the pics glgeek. I think the tongue on the newer #18 carts is a bit different, so I am not sure I can do this mod to it. However, my cousin is a welder and works in a fabrication shop, I think I may get him to build me an entirely new tongue for this trailer, as it is the weak point of these carts.
    #18 Steel cart.
    Front fender kit.
    Brush guard.
    SE seat.
Similar Threads
  1. Buying Advice Rocket Steel Buildings aka Centuria Steel Corp aka Aztec Steel, etc...
    By Vancouver Island Waterjet in forum Buying/Pricing/Comparisons
    Last Post: 03-02-2013, 10:23 AM
  2. Ballast Cart Solution
    By funwithahoe in forum Kubota Owning/Operating
    Last Post: 07-18-2011, 05:29 AM
  3. Steel underpan, front bumper, Steel cage??
    By pharmvet in forum Ag Tractors & Machinery
    Last Post: 02-01-2010, 12:38 PM
  4. Ohio Steel Flat Bed Dump Cart for BX
    By derecskey in forum Kubota Owning/Operating
    Last Post: 07-01-2008, 02:21 PM
  5. A-572 steel VS T-1 steel
    By stevenf in forum Build-It Yourself
    Last Post: 11-03-2004, 09:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
