Results 1 to 7 of 7
  1. #1
    Join Date
    Feb 2005
    Posts
    986
    Central WI
    Default 700 series 3point hitch
    I have the Cat 0 3ph on my 455 and it works just fine. With the new x700 series I have the option of the limited cat 1. Since the Cat 0 has worked fine for me for 16+ years now I plan to stick with this size, but just wanted to know if there was any reason to consider the Cat 1?
    My 450 tiller will attach to either with sliding brackets so hook up is not an issue.
    JD3720 300CX FEL, 48" forks, MX-5, RB1172, BB1172 air seat susp
    JD 455 2 wheel steer
    JD x750-Auto Connect w/60" HC deck
  2. #2
    Veteran Member CHDinCT's Avatar
    Join Date
    Jul 2008
    Posts
    2,456
    Conn. & Florida
    Kubota BX25
    Default Re: 700 series 3point hitch
    I think the obvious advantage to a Cat 1 would be greater availability of implements. The limited Cat 1 could use any of the new sub-compact three point implements now being offered. For example, TSC has a line of sub-compact three point implements. Also, easier to find used Cat 1 vs Cat 0 stuff.
    Chris
  3. #3
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,406
    central Iowa
    JD 2720
    To add to what CHDinCT said, with a Cat 1 hitch, you could get the I-match quick hitch takes all the work out of connecting rear implements.
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  4. #4
    Join Date
    Feb 2005
    Posts
    986
    Central WI
    In my case the only thing I ever use is the tiller or rear weight bracket so I'm thinking the Cat 0 would be plenty fine. No need to push the tiller further back with the Imatch. If I need to do real work I just use teh 3720. The small macine is for cutting lawn and roto tilling. I just wanted to make sure that there was no distinct advantage to the cat 1 that I could come to regret.
  5. #5
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,423
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Quote Originally Posted by KennedyDiesel View Post
    In my use the cat 1 hitch is far better in that all the implements I find are sized for it. Mot much cat 0 stuff available but lots of small cat 1 available everywhere. I have an IMatch on all my tractors including the x749 and it works great.
    Attached Thumbnails Attached Thumbnails 700 series 3point hitch-butch-w-new-lawn-work
  6. #6
    Elite Member Deere Dude's Avatar
    Join Date
    Feb 2011
    Posts
    3,120
    Beaver Dam Wisconsin then to Hohenwald, TN
    John Deere 3720
    I had a cat 0 for a lot of years and when I traded in for something else I jumped on the cat 1 hitch for the reasons others mentioned; more attachments to go with it. I did get a 6' rear blade and dirt scoop for it and worked great. I have a hydraulic tiller for it also and continue to use that.
    Since that time I bought a 3720 and use those attachments on the big tractor for obvious reasons. If I had it to do over again knowing I would keep my 3720, I would still get a cat 1 hitch, unless they are significantly more expensive.
    One thing does work good for for the winter months is a snowblower and rear blade combination. I blow the snow and after that drag the rear cat 1 rear blade over the concrete to get it down to the ground. 700 series 3point hitch-img_0381-jpg700 series 3point hitch-img_0823-jpg
    Of course I have to get the 3720 out once in a while to play in the snow, but would never have to.
    JD 3720 with R4s and bulldozer capabilities.
    X740
    13 Millimeter = 1/2"--------25 Milimeters=1"-----------100 Millimeter = 4"----------1 Meter = 40---------1 Kilometer = 3300' or 5:8 ratio
    A 13mm will but will be just slightly larger than a 1/2" nut.
  7. #7
    Elite Member Gittyup's Avatar
    Join Date
    Oct 2007
    Posts
    3,135
    Mid Atlantic
    Kioti CK25 Shuttle Shift, loaded tires, JD X739
    Pretty cool withy hat dirt scoop on there.
Similar Threads
  1. 3POINT HITCH CORDWOOD SAW
    By TL SASK in forum Wanted Ads
    Last Post: 04-14-2012, 06:02 PM
  2. 3-Point Hitch Faulty 3point hitch 885xl
    By welshkaiboy in forum Case-IH
    Last Post: 08-30-2011, 04:35 PM
  3. JD 4200 3point hitch valve
    By duksrule in forum Parts/Repairs
    Last Post: 04-09-2009, 10:26 PM
  4. Another 3point hitch
    By tatra805 in forum Build-It Yourself
    Last Post: 02-11-2009, 10:25 AM
  5. BX2230 3Point Hitch
    By dixy1dog in forum Kubota Buying/Pricing
    Last Post: 12-15-2005, 01:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
