Results 21 to 30 of 46
03-10-2013, 01:59 PM #21
Re: 54'' deck on X700 series.
I try not to cut too much off in one go, but the problem with BC is everything grows, instantly. If I cut the grass Monday morning, by that evening you can tell a difference if you look at it closely. I keep the grass very short so I can keep up with it. If I cut it by the rule of thumb, 1/3, by the time the weekend comes and I can get to it, it's so thick and heavy that the discharge quality is terrible. I am not a fan of bagging because clippings have a lot of nutrients and moisture in them that acts as a natural fertilizer that's free.
One benefit to the very short lawn is when we play fetch with the dogs they can find the toys easy!2012 John Deere X740, #18 steel cart, front fender kit.
03-10-2013, 03:12 PM #22Platinum Member
- Join Date
- Feb 2005
- Posts
- 935
- Location
- Central WI
Same here on the cut every other day in some situations. Over the past couple of years I have been raising my cutting height higher and higher. I feel that most cut too short. Having a taller lawn helps control weeds and I've been liking this in our case. I've been riunning in the neighborhood of 3 to 3.5" cut height I believe.
JD3720 300CX FEL, 48" forks, MX-5, RB1172, BB1172 air seat susp
JD 455 2 wheel steer
03-10-2013, 03:13 PM #23Member
- Join Date
- Feb 2013
- Posts
- 29
- Location
- Pennsylvania
- Tractor
- John Deere 318, Kubota L4200 GST
I hear what you're saying and am with you on all of that. Accept my grass here in PA doesn't grow quite as fast as yours in BC. Accept maybe early Spring. But I swear the Dandelions duck their heads every time I make a pass while mowing. Mow in the morning and they are taller than the cut grass in the afternoon, all season long.
03-10-2013, 03:21 PM #24
03-10-2013, 03:46 PM #25
I don't like the idea of mulching because your keeping everything underneath the deck. Grass has nowhere to go but down, and if the grass is damp at all, your deck will be clogged full in no time. I have found with mulching that cleaning the deck becomes a very regular thing.
My plan is to run gator blades on this deck. They did wonders on the old Craftsman, so they should do even better here. I found with the gators as long as the grass didn't get away on me, you could never tell I didn't bag it, and the underside of the deck was clean too.2012 John Deere X740, #18 steel cart, front fender kit.
03-11-2013, 09:58 PM #26Veteran Member
- Join Date
- Oct 2007
- Posts
- 2,411
- Location
- Mid Atlantic
- Tractor
- Kioti CK25 Shuttle Shift, loaded tires
Cutting it longer doesn't mean cutting more grass. You still cut at the same timer intervals between mowing, and you cut off the same amount. A taller lawn is healthier, less likely to scalp, reduces weeds, and holds up better when it's dry. You should never cut below about 3" on most grass types no matter how fast it grows.
03-11-2013, 10:46 PM #27Platinum Member
- Join Date
- Jul 2010
- Posts
- 842
- Location
- Rockland county, New York
- Tractor
- Kubota B26, John deere X595
2010 Kubota B26 TLB w/hyd thumb. 2004 John Deere X595 w/62" MMM.
Carl Bertuzzi
03-11-2013, 11:27 PM #28
I would have to agree with you there.
For me, the gratification comes from seeing your results immediately. You look behind you and see a beautiful lawn, while in front of you is uncut grass. It is nice to see that discharge chute spewing nice grass clippings on a sunny day.2012 John Deere X740, #18 steel cart, front fender kit.
03-12-2013, 12:05 AM #29Super Member
- Join Date
- Feb 2008
- Posts
- 7,732
- Location
- somewhere usa
- Tractor
- stuff
I agree with cutting when it is about 4.5 inches and cutting it to 3.0 inches The grass just looks better and weed free for the most part.
03-12-2013, 12:31 AM #30Elite Member
- Join Date
- Feb 2011
- Posts
- 3,804
- Location
- NOT HERE
- Tractor
Here is a site that has the recommended cutting heights for different types of grass.
Mowing-Mow it High and Let it Lie
I have noticed that too at least for my grass.
Similar Threads
X700 series mower deck interchange
By KennedyDiesel in forum John Deere Lawn & GardenReplies: 24Last Post: 05-12-2013, 09:32 PM -
New X700 series.
By JDTank in forum John Deere Lawn & GardenReplies: 20Last Post: 10-31-2012, 10:40 AM -
X700 series
By zlock24 in forum John Deere Lawn & GardenReplies: 74Last Post: 01-16-2012, 09:18 PM -
X700 series replacements?
By JB2 in forum John Deere Owning/OperatingReplies: 3Last Post: 07-16-2011, 08:36 AM -
Anyone on here went from a JD X700 series to a BX and regretted it?
By Grateful11 in forum Kubota Owning/OperatingReplies: 6Last Post: 12-23-2010, 10:09 AM
