Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    Member RonS's Avatar
    Join Date
    May 2011
    Posts
    40
    New Brunswick
    JD 2520 & X740
    Default Re: Picture of 2012 X748 and 2013 X738
    Quote Originally Posted by Nooodles View Post
    don't mean to sound like a party pooper but aren't you the guy that started an accessories thread adding stuff like this. mud flaps and curb feelers and hubcaps and such. Just sounds like a contradiction
    You might want to read his post again. I didn't see JDTank mention any of the things that you state. Looks like trolling to me.
    JD 2520; 53" FEL; SS1067B Spreader; BB2060 Box Blade; 54" Front Mount Blower; iMatch; Ken's Grab Hooks; Front and Back Lighting Kit; Artillian Forks; Artillian Worklight Horse Blinders; Artillian Caster Carts; BX42 Chipper; X7XX seat and suspension
    X740; 60" Mower; Brush guard; Brinley dethatcher; 920 lb Ohio Steel roller; aerator; JD suitcase weights; 25 gallon JD sprayer, Brinley 17P cart; Quik-tatch; custom hazard lights
  2. #22
    Join Date
    Feb 2009
    Posts
    1,310
    NC
    Quote Originally Posted by jbgood View Post
    As far as looks go on the 2012 and the 2013, I like them both. Last year (March) I was all set to buy a X728. Then I had a stroke in May and that put an end to the tractor idea. Now this year I'm about 75% better and have X738 on order. Actually it's better it worked out the way it did because the 2013 offers the drive over deck and will make it a lot easier for me. Quick attach drive over deck and quick attach snowblower should make life a Lil' better as I can't quite do things as I could when I was looking last year.
    It's good to hear that you are recuperating from your stroke. I bet you'll have a big ol' smile on when get on that X738.
    '11 John Deere 5065M /cab
    '10 Kubota L3940 w/FEL
    '09 JD X720
    '91 CaseIH 5140 Maxxum w/cab
    '78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
  3. #23
    Veteran Member ccsial's Avatar
    Join Date
    Jun 2005
    Posts
    1,632
    NorthWest Illinois
    (Kuboto L3400) (Ford 1910 4WD w/FEL) (Deere X748SE) All bought new
    Quote Originally Posted by KennedyDiesel View Post
    The 748 appears to be a 2008 era model with MFWD.
    Yes it is. They probably just used an old file photo.
    Kubota L3400-HST, Ford 1900-Gear FEL, John Deere X748SE
  4. #24
    Gold Member eagle107's Avatar
    Join Date
    Jul 2011
    Posts
    374
    NY
    John Deere and New Holland/Ford Tractors
    Quote Originally Posted by jinman View Post
    I like the simple clean lines of the older model. I'm sure the paint shade difference is just a photo issue. There is something very attractive to me about JD lawn machines with the contrast of yellow and green.
    In the photos, the decks sure seem different. On the X748, the deck is flat over the spindle and looks like it has a drive-over pad so you can disconnect easily and drive over the deck. The newer X738 has a bracket over the spindle that I think would be a challenge to drive over. However the trailing links from the front axle to the deck look more beefy on the 2nd model. The anti-scalp wheels and structure look about the same. Aren't the new decks made of lighter weight materials? To me, the deck is the heart and soul of a great mower.
    Here are some pictures of the 7-iron deck (green deck) you were talking about and pictures of the new deck 9ga deck (new yellow deck). I still like the 7-iron better myself, but I am bias because I own one.
    Picture of 2012 X748 and 2013 X738-7-iron-vs-9gav2-jpgPicture of 2012 X748 and 2013 X738-7-iron-vs-9ga-jpg
    John Deere and New Holland/Ford Tractors and stuff
  5. #25
    Gold Member
    Join Date
    Feb 2013
    Posts
    476
    Pennsylvania
    Kubota L4200GST John Deere X758 Previously owned: J.D. 318, I.H. 354, J.D. 2350
    The merits of the "old" verses "new" could be argued until the cows come home. I have got to give you credit, eagle107, at least you admit being biased in favor of the one you already own, which I suspect is the case of another one or two owners. Human nature. Having owned neither, I think both are equally as good, but the 7-iron is definitely a commercial quality deck.
  6. #26
    Platinum Member bubbacuse77's Avatar
    Join Date
    Jul 2008
    Posts
    575
    Wisconsin
    John Deere 3520, John Deere X749
    I just ordered a new 2012 x749 that my dealer is getting from another state. I like the old style hood vs the new look. The seat on the new ones is nice but i'm sure i could swap that onto the 2012. I really wanted 4wd, AWS, and a diesel. That combination is no longer availible I am told because the tractor would require a ROPS. The dealer shot me a great deal with the 1K rebate from Deere of 11K. My only real hang up is on the deck. I understand you can't put a 7 iron deck on an 2012 AWS model. I really don't want to pay $1500 more for a 2013 gas engine just to get a better deck. I'm not sure if the drive over deck is that important if I still need to get under the tractor to disconnect stuff only to either get back on the tractor to drive off it or slide it out the side. Either way I am going to have to move it because I am not going to leave it in the middle of the floor. Has anyone successfully fit a 7iron deck to a AWS model? I really like the higher capacity for mulching and the thicker medal.
    Sorry for being a windbag.
  7. #27
    Member
    Join Date
    Feb 2012
    Posts
    45
    Wisconsin
    2013 JD X738
    Bubba, Not sure where you got your info. But if you go to a JD website you'll find the X754 is a diesel with 4x4 and AWS. Also the 739 is 4x4, AWS with a gas engine. I think the cost of that seat may shock you a bit. FYI John Deere has a 500.00 coupon out now that is good until April 31. Start working with a dealer and by the time your done you'll find that a new tractor can actually be less than what the 2012 was when new. as far as I know none of the 700's require a ROP.
  8. #28
    Join Date
    Jul 2008
    Posts
    575
    Wisconsin
    jb,
    Thanks for the response but check your research again. The 2013 x754 is indeed AWS and a diesel but it is not 4WD. X749 is the only AWS, 4WD, Diesel. Verified by JD web site and every dealer I have talked with. So there really is no compatible new model.
  9. #29
    Member
    Join Date
    Feb 2012
    Posts
    45
    Wisconsin
    2013 JD X738
    Ya' thats correct. You caught me on that one. I think you must have meant to say 739 instead of 749. I just picked up some Lit. this morning and yes it does show the X739 with 4WS and 4WD but the X754 as diesel and 4WS only. Happy to say I did just sign the paperwork today for a X738 4WD.
  10. #30
    Join Date
    Jul 2008
    Posts
    575
    Wisconsin
    Jb, how long till you get it? If I can ask, how much was it before taxes and what size deck did you get? I still have time to change my mind to a 2013.
Similar Threads
  1. Question on cabs for X738
    By jbgood in forum John Deere Owning/Operating
    Last Post: 02-22-2015, 09:23 PM
  2. 2012 vs 2013 X300 issue
    By eagleguy in forum John Deere Buying/Pricing
    Last Post: 03-07-2013, 04:23 PM
  3. x738 Brush Bar
    By jbgood in forum John Deere Lawn & Garden
    Last Post: 02-24-2013, 03:41 PM
  4. 2013 X738
    Last Post: 02-07-2013, 10:26 PM
  5. 2012-2013 Food Plots
    By lakngulf in forum Food Plots
    Last Post: 12-05-2012, 02:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
