View attachment 308744 JD, Notice in the picture I attached. This brush gaurd on this 2013 is diff. than the one shown on yours. Question is : Is your distinctfully a 2012 brush gaurd or is there a choice in which type a pearson can order
JD tank,I want to tell ya I had my rear tires loaded with rimguard and it really helps with traction if you want to go that route.coobie
I thought about it, but in the winter months, and the spring months such as now, I need to keep my weight as light as possible. Even with just the tractor and no attachments, I have a few very soft spots where I sink and leave big ruts in the lawn. Since we get very large amounts of rain here, the ground is saturated with water 7 months of the year.
I think what I am going to do is just order the rear weight bracket and the click-n-go setup. I will use suitcase weights if I need them. This way the weight is easily/quickly removable.
I have to put the brakes on any more accessories/upgrades for now, I already put $700 on my Ag-Line account yesterday to get the 18 cart, the brush guard, some paint, oil and other supplies. I want to save the big upgrades for winter time when I have nothing to do but be out in the garage. In the winter I will do the rear PTO shaft, 3PT hitch, and the SE seat. If I can make some good money this year, I really need a 54'' blade with the quick hitch setup. So much work I could do but cannot afford it right now.
hi JD
i think you will find that there will be a lot of slop in the drawbar with the receiver kit as well. if you figure out how to tighten it up, let me know. i use a couple different drawbar drops to keep whatever i connect fairly level. both of them bang around when driving over uneven ground.
after you cut off the front of the tongue and bolt on a ball hitch, paint it yellow or green
Take your time and enjoy it. Like they say, anticipation is sometimes more enjoyable then the act itself. Do one thing at a time. Those are some expensive upgrades you're looking to do. By the way, that's a beautiful setup you have there. Great looking cart.
Cut a piece of conduit, either metal or plastic to fit in the gap or space. Slide the pin through the conduit, insert the keeper and no more trailer movement.
