Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    4
    Horace ND
    x475 JD
    Default Rear PTO add on JD x475
    Does anyone have the part number for the rear pto add on kit for a 2006 john deere x475 garden tractor? Any information is greatly appreciated, thanks
    Attached Thumbnails Attached Thumbnails Rear PTO add on JD x475-jd-x-475-jpg
  2. #2
    New Member
    Join Date
    Feb 2010
    Posts
    11
    Fort Worth,Texas
    JD X585
    Default Re: Rear PTO add on JD x475
    The original PTO for the x4..and x5.. tractors is BM20633. It was later replaced by BM21914. The main difference was that the original BM20633 had all of the required parts. BM21914 will work on the x4.. x5.., and was used on the x7.. series early on. The x7.. series tractors had the control module, AM120840, already installed and was not needed, so it was eliminated from the kit. If you get the new BM21914, you will need to order the control module AM120840. If you can find BM20633, the module is included. There was a later PTO kit, BM23588, released for newer x7.. series after June 2010 that will not fit the x4.. or x5.. series.
Similar Threads
  1. Add a rear remote on a jd 3320
    By sparker133 in forum Hydraulics
    Last Post: 10-28-2010, 05:53 AM
  2. Will JD 317 rear wheels fit a JD X475?
    By Deadman in forum John Deere Lawn & Garden
    Last Post: 12-11-2008, 06:58 PM
  3. rear pto add on
    By Les Loewen in forum Attachments
    Last Post: 09-19-2008, 08:57 PM
  4. Grading want to add rear blade
    By MrChris in forum Mahindra Owning/Operating
    Last Post: 04-10-2007, 10:48 PM
  5. Rear hydraulic add on
    By Momboy007 in forum Chinese Tractors
    Last Post: 02-01-2006, 12:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
