Results 1 to 6 of 6
  1. #1
    Join Date
    Dec 2008
    Posts
    50
    Northern Indiana
    John Deere 2320, 2520, 5303 and Farmall Super C
    Default 2320 and 2520 Tach Die
    I have both a 2320 and a 2520 and I am having a terrible time with the tach, I have replaced the 2320 tach and cable at 315 hours and now my 2520 died at 285 hours. I have asked my dealer to check with Deere to see what's going on. At $400 to $500 a pop I hesitate throwing away money again for a short-lived fix. Anybody out there have similar experience? And by the way, I'm out of warranty.
    1952 Farmall Super C, 2005 JD 2320, 2008 JD 2520
    2008 JD 5303, 200CX FEL w/ 54" Bucket and 56" Manure fork, 54D MMM and 62D MMM
    Frontier RT1160 Tiller, JD LX4 Rotary Mower
    I-Match 3-Point hitch
    JD LX7, 7' Rotary Cutter, JD KBA 10' Wheel Disc
    54" Snow Blower, 54" Blade
  2. #2
    Member
    Join Date
    Apr 2013
    Posts
    33
    Sarasota, FL
    JD 2320
    Default Re: 2320 and 2520 Tach Die
    I just had my dash apart and have a solution. I have a 2320. Mine died at 117 hrs. Here is the deal. The tach is getting moisture in it and seazing up which causes the cable to break. Simply replacing the cable will not solve the problem but you don't need a new dash.
    What I did:
    Removed cable and found it twisted off at the engine. It looked like it still had a bit of oil on it so I was curious as to why it would break. I pulled the dash and found the tach locked up. I simply removed the 2 little screws in the back to pull off the cable connection and the one drive gear and with a little wd40 I was able to free up the shaft. I then hooked up my cordless drill and spun it up and kept hitting it with wd40 until the rust stopped coming out. Cleaned everything up (I just washed it in dawn and warm water) I left it out to dry tonight and will get a new cable tomorrow. The only way to keep this from happening is to lube it once in a while (the back of the dash) or keep your tractor out of the rain.
    Sorry in advance as i don't do pictures because I work alone. It is very obvious once you get the dash off.
    Warning: If your tach quits DO NOT replace the cable unless you free up the tach first as you will just destroy the new cable!
  3. #3
    Join Date
    Dec 2008
    Posts
    50
    Northern Indiana
    Thanks rshrimp! I dove into the meter assembly and found the shaft that spins the meter was stuck. I sprayed some penetrating oil into the area and got it freed up and all works well. I am concerned that this is not a permanent fix. I suspect that once the lube wears off it will stick again. I also believe a new meter eventually will do the same. According to my dealer, Deere has no failure history on this part.
  4. #4
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default
    Quote Originally Posted by jimjo2 View Post
    Is your tractor typically stored inside or outside.
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  5. #5
    Join Date
    Dec 2008
    Posts
    50
    Northern Indiana
    Never sits outside.
  6. #6
    Member
    Join Date
    Apr 2013
    Posts
    33
    Sarasota, FL
    JD 2320
    What i did was put a dab of grease under the black thingy where the 2 gears mesh. Should keep it free for a long time. I am going to add this proceedure to my 100 hour service. It only takes a few minites.
Similar Threads
  1. 2520 tach
    By PCABE5 in forum John Deere Owning/Operating
    Last Post: 03-22-2016, 03:17 PM
  2. 2320 vs 2520 is the 2520 worth 2K more????
    By 70stang in forum John Deere Buying/Pricing
    Last Post: 06-10-2011, 07:47 PM
  3. Front Hitch Quik-Tach on 2320
    By Matt Heath in forum John Deere Owning/Operating
    Last Post: 10-14-2008, 10:20 PM
  4. 2320 vs. 2520... what do you get for 10% more HP?
    By bxowner in forum John Deere Buying/Pricing
    Last Post: 12-24-2007, 12:49 AM
  5. 2320/2520 - Any Available?
    By psdx in forum John Deere Buying/Pricing
    Last Post: 12-04-2006, 07:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
