Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Apr 2011
    Posts
    42
    Deere 5085e, 3320
    Default Powerflow on a 455
    I have a question for any of you running a 455 (or similar) with a 60deck and a powerflow unit. I recently pickup a new unit for a dealer that was clearing out some old inventory. I was complete except the instructions. I've got it all figured out except for one thing. There was a short rubber bungee connector with a screw hole on one end and a metal "catch" on the other end. I can't find for the life of me where it is used if if it is used. Anyone running a similar setup help shed a little light on this?
    Also, when you put your drive belt into lock mode, is it fairly tight or does it have some slack in it? mine seems to and I don't want to damage anything because if it. It still drives the pulleys without a problem.
    Thanks,
    Scott
  2. #2
    New Member
    Join Date
    Aug 2005
    Posts
    8
    Green Bay, WI
    JD 4110/JD 445
    Default Re: Powerflow on a 455
    hmmm....The only thing I can think of may be the strap that connects the chute to the housing. Does it look item 3 in the picture?
    Attached Thumbnails Attached Thumbnails Powerflow on a 455-mp6294_________un01jan94-gif
  3. #3
    Member
    Join Date
    Apr 2011
    Posts
    42
    Deere 5085e, 3320
    Yep that is it. So that keeps the chute connected to the mc519 or the power flow?
  4. #4
    New Member
    Join Date
    Aug 2005
    Posts
    8
    Green Bay, WI
    JD 4110/JD 445
    It connects between the bottom of the chute and the power flow housing (on the deck). The strap prevents the chute from falling off the housing.
  5. #5
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,425
    central Iowa
    JD 2720
    I have been wondering where mine came from. I sold my MC519 bagger a long time ago and it has been sitting on the shelf ever since. Thanks for bring it up.
    Powerflow on a 455-042503_1407-00-jpg
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  6. #6
    Veteran Member jeffinsgf's Avatar
    Join Date
    Mar 2005
    Posts
    1,256
    Springfield, MO
    JD 4410
    That's what I use mine for, though I pull it pretty tight and hook it on top where it is easier to get to. Keeps the chute attached to the PowerFlow and the other end floats in the MC-519.
    And, my belt also has quite a bit of slack. Doesn't seem to slip, but it isn't tight. It will slip if the blower gets clogged, so that might be the theory behind the amount of tension.
    4410 ePR, 3rd SCV, Skid Plates, TuffTop Canopy
    430 FEL, 48 BH, MX-5, Bush Hog Chipper, and more.
    455, 60" deck, MC-519, 3pt hitch
Similar Threads
  1. Powerflow system
    By par4n1 in forum John Deere Lawn & Garden
    Last Post: 01-25-2011, 01:41 AM
  2. Powerflow for leaf collection
    By Builder in forum John Deere Lawn & Garden
    Last Post: 11-12-2010, 10:30 AM
  3. What is the powerflow option?
    By Iowa Boy in forum John Deere Buying/Pricing
    Last Post: 05-16-2007, 02:10 AM
  4. 2305 powerflow system vs Cyclone Rake (Powerflow review)
    By orlo in forum John Deere Owning/Operating
    Last Post: 07-30-2006, 04:32 PM
  5. Powerflow isn't so powerful? Please advise.
    By Trouble in forum Attachments
    Last Post: 09-30-2003, 11:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
