Results 1 to 2 of 2
  1. #1
    Join Date
    Feb 2005
    Posts
    986
    Central WI
    Default 540 pto
    The PTO on my 455 is an "inny" or female spline. The new ones are apparently now male. My sole implement is my 450 tiller. It has the male end to match the 455 so I'll need to change this out. Then I'll need a stub shaft correct?
    No clutch in the driveline yet is there? The PTO clutch takes the load?
    JD3720 300CX FEL, 48" forks, MX-5, RB1172, BB1172 air seat susp
    JD 455 2 wheel steer
    JD x750-Auto Connect w/60" HC deck
  2. #2
    Join Date
    Feb 2005
    Posts
    986
    Central WI
    Default Re: 540 pto
    Talking through the potential answer to my own question
    M112354 shaft should get me my stub. From there:
    Assuming that std 540 pto is 1.375-6 spline
    The universal joint used with my current PTO shaft is AE22753 and specs at 1-1/8 diameter and 2-11/16 width.
    This closely matches a 14 series driveline which is 1-1/8 and 2-5/8
    Weasler 100-1406 14 SERIES 1.375-6 SPL QD YOKE appears to be what I would need?
    L14 / 2000 Series Series Ag PTO Parts
    The only thing that I don稚 see is what machining there is for the retainer clips, but I assume this is a std setup.
Similar Threads
  1. PTO yoke won't slide on
    By tony83 in forum Attachments
    Last Post: 05-07-2013, 04:05 PM
  2. Ford 7700 PTO
    By Bullseye77 in forum New Holland Owning/Operating
    Last Post: 05-07-2013, 07:53 AM
  3. pto speed 540 rpm on John Deere 3720
    By sawyer22 in forum Attachments
    Last Post: 05-01-2013, 08:00 AM
  4. PTO Power?
    By philurbs in forum Owning/Operating
    Last Post: 04-27-2013, 08:32 PM
  5. MF1240 PTO ISSUE
    By DONALDK in forum Parts/Repairs
    Last Post: 04-25-2013, 07:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
