Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jun 2013
    Posts
    2
    Spivey Kansas
    John deere F935
    Default F935 Mower deck hub bearing replacement problem
    I have a JD f935 72" front deck mower. I have been mechanicing for most of my life so this really has stumped me. I can't get the shaft to press out of the hub assy. Do I need to heat up the hub? I don't like that idea as I believe it will damage the seals. I have already broke one housing (hub)trying to press the shaft out. I am pressing on the bolt that holds the blade on. Does anyone have any tips for replacing the bearings in the hub?
  2. #2
    Veteran Member joecdeere's Avatar
    Join Date
    Apr 2002
    Posts
    1,147
    Cumming,Georgia
    1948 Allis UC Hi-Crop Cane 1941 Allis WC 1948 Allis G 1948 Allis G 1949 Allis G 1954 Allis G 1959 Ferguson TO-35 1972 MF 135 1979 Power King 2418 1989 Ford 345C TLB
    Default Re: F935 Mower deck hub bearing replacement problem
    looks to me that you would remove the nut holding the pulley on, remove pulley and key. Then press the shaft out through the bottom of the housing
  3. #3
    New Member
    Join Date
    Jun 2013
    Posts
    2
    Spivey Kansas
    John deere F935
    I got it worked out. The disc on the blade end of the shaft screws off and the shaft then pressed out real easy. Thanks for your input.
Similar Threads
  1. Replies: 0
    Last Post: 06-08-2013, 02:26 PM
  2. Farm King mower-bearing replacement
    By Mean Jean in forum Parts/Repairs
    Last Post: 04-22-2011, 09:37 PM
  3. Thoughts on JD F935 front deck mower
    By CentralNC in forum John Deere Lawn & Garden
    Last Post: 10-12-2010, 09:27 PM
  4. F935 mower deck?
    By brianMO in forum John Deere Buying/Pricing
    Last Post: 04-18-2008, 10:28 AM
  5. Mowing bearing on mower deck needs replacement
    By lukas2000 in forum Cub Cadet Tractors
    Last Post: 05-05-2005, 07:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
